- use only the approved power adaptor that came with your Hub. Don’t use it if the casing or cable is damaged
- don’t put your Hub on thick carpet or other surfaces that may obstruct the ventilation holes
- place the Hub away from direct heat sources such as radiators, fireplaces or windows in full sunlight. We recommend a maximum operating temperature of 40°C
- don’t put your Hub somewhere where it will be splashed or subject to high humidity such as a bathroom, shower or sink
- avoid areas of extreme cold or condensation. We recommend a minimum operating temperature of 10°C
- power and LAN cables can be a trip hazard, so make sure you route them carefully
- keep a distance of at least 20cm (8 inches) between yourself and the Hub, especially if it’s on a table or somewhere you regularly sit
- you can clean your Hub with a soft dry cloth. A microfibre cloth is ideal but don’t use solvents or abrasive cleaners
- don’t try to open your Hub – there are no user serviceable parts inside
Safe use of your EE Smart Hub
Last updated: 20/2/2019
Simon H posted this. Got a comment? Good or bad, we'd be pleased to hear from you.
Was this article helpful?
Great!
Thanks for your feedback
We'll use your feedback to keep improving our help articles
