Firewall card
Your TG589 router comes with an integrated firewall that helps you protect your network from attacks from the internet. This firewall has a number of predefined levels to allow you to adjust the firewall to your needs.
The default mode is normal. In normal mode, the firewall will:
  • allow all outbound connections and will silently drop all unknown incoming connections
  • protect your TG589 router and local network against intrusions
Firewall card
The Firewall card displays current firewall level used.
Viewing additional settings
Select Firewall. The Firewall page appears and allows you to:
  • change the firewall level
  • enable or disable response to internet pings
Last updated: 13/2/2019
Was this article helpful?
  • Please select a reason
  • The article is too long
  • The article doesn't make any sense
  • Other Reason
0/600
Great!
Thanks for your feedback
We'll use your feedback to keep improving our help articles
WAN Services card
Diagnostics and assistance
