Internet Access card
The Internet Access card displays:
  • the current status of your Internet connection
  • the WAN IP address
This is the IP address that your TG589 router uses for its communication on the internet.
Internet Access switch
In the Internet Access card header, you can see whether your broadband interface is enabled or not. If the switch is set to:
  • then your main internet connection is enabled. Clicking the switch will disable your main internet connection.
  • then your main internet connection is disabled. Clicking the switch will enable your main internet connection.
Viewing additional settings
Select Internet Access. The Internet Access page appears and displays additional settings.
Last updated: 13/2/2019
Simon H posted this. Got a comment? Good or bad, we'd be pleased to hear from you.
Was this article helpful?
  • Please select a reason
  • I didn't understand the article
  • I found the information but it didn't resolve my issue
  • Please let us know how we can make it better
0/600
Great!
Thanks for your feedback
We'll use your feedback to keep improving our help articles
