How do I enable roaming?
Enabling calls and text
Text ROAMING to 150 before you go or enable international calls and texts from MyEE.
Enabling data
To use your data you need to enable roaming on your device.
How can I reduce costs?
Turn off ‘Wi-Fi Assist’
(iPhone only)
iPhones have a feature which may use your data even when you’re connected to Wi-Fi. Learn how to turn it off.
Reduce how many
characters you text
Every 160 characters count as a text. So, if you send a text longer than this, you will get charged for multiple text messages.
Travelling near Turkey?
You’ll get charged international roaming rates if your device connects to a Turkish network. To avoid charges, check you're on the right operator in your device settings whilst abroad.
