Sorry! No results found but hit enter for the most relevant articles.
How do I set up and use Apple TV 4K?
In this article
Get help on setting up and using your Apple TV 4K.
How do I connect Apple TV 4K to my EE Broadband and TV?
Apple TV 4K includes a power cable and we'll send you an HDMI cable free of charge.
You'll need to plug your Apple TV 4K into a power socket and then connect it to your TV with the HDMI 2.0 cable. You can connect to the internet using an Ethernet cable from your Apple TV 4K to your router or you can connect to WiFi during set up.
Once you've switched on Apple TV 4K, follow the onscreen instructions to configure your settings. Alternatively you can transfer your settings from an iOS device.
Yes, but you won't be able to view content in 4K HDR quality.
How do I use Apple TV 4K?
Apple TV 4K is easy to use and you can watch movies and TV shows, view photos and listen to music or podcasts. Plus you can change settings for video and audio, use Siri as a remote, search for content, set parental controls and much more.
Can I use my iPhone or iPad as a remote control for Apple TV 4K?
Yes, there's an Apple TV Remote on iOS devices. If your device has the latest version of iOS, the Apple TV Remote is automatically added to your Control Center:
open Control Centre
select Apple TV Remote
select your Apple TV 4K from the list
enter the four-digit passcode that appears on your TV screen
