How to fix Freeview reception issues with EE TV
In this article
EE TV lets you watch over 70 free digital TV channels through a TV aerial.
> Check the full list of digital TV channels in your area
If you're having problems picking up all the channels available in your area; or with the quality of your digital TV service, see our tips below for
more help.
Can’t see programme info for ITV4 in your EE TV Guide?
> See how to re-scan your Freeview channels
Check your digital TV coverage and channels
Check the Digital UK coverage checker. This site shows which channels are available in your area and the quality of reception you can expect.
Planned maintenance
You can check Digital UK's planned engineering works for details of any maintenance or developments in your region. If your TV service has suddenly stopped working and you've not changed anything, it may be a temporary issue. The site will also let you know when you need to re-scan your channels.
Check your TV aerial and set-up
Many problems with digital TV are caused by problems with your aerial, or basic aerial set-up.
> See how to fix problems with your EE TV aerial
Re-scan your EE TV channels
From time to time, you'll need to re-scan your EE TV channels. If you've just fixed a problem with your aerial cable set-up or you've bought a new aerial, a quick re-scan will help get you up and running.
The weather
Believe it or not, the weather can have an effect on the quality of your television picture – especially if you're using a set-top aerial. Snow, high winds or high-pressure weather can all cause problems with your picture. If this becomes annoying, consider fitting a new rooftop (or loft) aerial.
4G phone signals
Occasionally, signals from 4G masts can cause issues with digital TV signals. You may have got a postcard from at800 if they predicted you may be affected. You can find out more from at800.
Still having problems?
Try restarting all your TV equipment:
  • unplug your EE TV, TV and any connected devices e.g. games consoles, DVD players, Blu-ray players
  • wait 30 seconds
  • plug all your equipment back in and wait for them to restart
Thanks for your feedback
Give us a call
Give us a call
Call now
150
Free to pay monthly
25p per call on pay as you go
Open
Closed
Bank Holiday Monday opening times: 08:00-20:00
Mon to Fri
Sat
Sun
Ask the Community
Ask the Community
Ask questions and share tips with other people 24 hours a day
Book an appointment
Book an appointment
You can book a phone appointment with one of our local experts.
Something went wrong. Please try again later We cannot identify your location. Please enter your postcode below
Finding you
Open Mon to Sat
Open Sun
Need more help
