How can I fix my connection issues with EE TV?
In this article
Buffering on EE TV
Buffering on EE TV
Buffering can cause your on demand content to pause or break up – you might see a circling spinning symbol on your screen.
Check your WiFi quality
Go to TOOLS & HELP > STATUS. Above 60 per cent is OK. If it’s lower, you can try to improve your WiFi performance
Check your broadband speed
> Learn how to check and improve your broadband speed
Check other on demand services
Try using other on demand channels on your EE TV. If other services are working fine, there may be a temporary problem with the on demand channel you're trying to use.
Try rebooting your EE TV and router
Try switching off then unplugging your EE TV from the mains. Wait 30 seconds before plugging it back in and switching on again. Still not working? Try doing the same with your router.
Problems with the sound or picture
Basic checks
  1. turn the volume up on both your EE TV remote and your TV remote
  2. make sure your TV isn’t on mute
  3. check the HDMI cable is securely plugged into your EE TV and TV
  4. if you have a surround sound system, check that too
Switch off and on again
Unplug your EE TV and your TV. Wait 30 seconds then plug everything in and switch on again.
Check your EE TV sound settings
  1. 1
    press MENU on your EE TV remote
  2. 2
    use the arrow buttons to go to TOOLS & HELP > SETTINGS > SOUND & PICTURE > AUDIO OUTPUT MODE
  3. 3
    choose BEST FIT or, if you have a home cinema set-up, try HOME CINEMA or DIGITAL STEREO
  4. 4
    press OK
Problems with digital channels only
If you're just having problems with your digital TV or radio channels, there could be a problem with your digital signal. See how to fix Freeview problems on EE TV.
Restore EE TV settings
If you're still having problems you can try restoring your EE TV default settings:
  1. 1
  2. 2
    use the arrow buttons to go to TOOLS & HELP > SETTINGS > ADVANCED SETTINGS
  3. 3
    enter your PIN
  4. 4
    press Reset settings, then CONTINUE
  5. 5
    your EE TV settings will reset to default settings and the box will restart
  6. 6
    after about a minute, you'll see the WELCOME TO EE TV page
  7. 7
    you can now follow the onscreen instructions to set up your EE TV
Thanks for your feedback
Give us a call
Give us a call
Call now
150
Free to pay monthly
25p per call on pay as you go
Open
Closed
Bank Holiday Monday opening times: 08:00-20:00
Mon to Fri
Sat
Sun
Ask the Community
Ask the Community
Ask questions and share tips with other people 24 hours a day
Book an appointment
Book an appointment
You can book a phone appointment with one of our local experts.
Something went wrong. Please try again later We cannot identify your location. Please enter your postcode below
Finding you
Open Mon to Sat
Open Sun
Need more help
