How do I fix On Demand TV Problems?
In this article
Having problems with on demand, like buffering or apps that won't load? There are a few simple checks you can do to fix the most common problems.
How do I check I'm connected to EE Broadband?
It's important that your EE TV is connected to your EE Broadband service. To check:
  1. 1
    press MENU on your EE TV remote and go to TOOLS & HELP STATUS
  2. 2
    from here, you can check your Local network IP address and Internet status
If the Local network IP address shows as In progress, see how to fix connection issues.
If the Internet status shows as Disconnected, you'll find more help in our router guides:
  1.
    Smart Hub
  2.
    Bright Box 2
  3.
    Bright Box
How do I check my WiFi quality?
If you're connecting using WiFi, check the quality is OK.
Above 60 per cent is fine – if the quality’s low, you may find you get buffering problems when watching on-demand content or problems opening the app.
See how to improve wireless performance or consider using Powerline adaptors to extend your broadband connection from your router to your EE TV.
How do I check my connection speed?
If your picture is freezing or buffering, it's worth checking the speed of your broadband connection.
> See how to test your broadband speed.
What should I do if I'm having problems using content in an app?
If you're having problems using on demand apps, there may be a problem with the service itself. If you'd like help, you can contact the provider of the app directly.
> See our useful contacts for on demand apps.
What should I do if I'm still having problems?
It may help to reset your EE TV.
> How to restore EE TV default settings.
Thanks for your feedback
Give us a call
Give us a call
Call now
150
Free to pay monthly
25p per call on pay as you go
Open
Closed
Bank Holiday Monday opening times: 08:00-20:00
Mon to Fri
Sat
Sun
Ask the Community
Ask the Community
Ask questions and share tips with other people 24 hours a day
Book an appointment
Book an appointment
You can book a phone appointment with one of our local experts.
Something went wrong. Please try again later We cannot identify your location. Please enter your postcode below
Finding you
Open Mon to Sat
Open Sun
Need more help
