How can I fix recording problems with EE TV?
In this article
If you're having problems recording a programme or watching programmes you've already recorded, we can help you fix it.
Check you're connected to EE broadband
While recording doesn't use an internet connection, your EE TV needs to be connected to EE Broadband to allow all the features to work. To check your EE TV is connected to your EE Broadband:
  1. 1
    press MENU on your EE TV remote
  2. 2
    go to TOOLS & HELP > STATUS and press OK
  3. 3
    check your internet status is Connected
If the local or internet status shows as in progressfind out more about connection issues.
You have too many recordings
You'll see YOU HAVE TOO MANY RECORDINGS if you try to record too many programmes at once – you’ll need to delete one of your older recordings.
Your EE TV can record up to four channels if Replay is turned off, or two programmes if Replay is on.
Recording starts too late or ends too early
Your EE TV works out when a programme will start and finish. You can always record a little bit extra just to be on the safe side.
  1. 1
  2. 2
    go to TOOLS & HELP > SETTINGS and press OK
  3. 3
    go to RECORDINGS and use the arrows to change the extra recording time before and after a programme
  4. 4
    press CONFIRM, then OK
Hard drive full
Hard drive full
Your EE TV comes with a terabyte (1TB) hard drive. So there's plenty of room for recording all your favourite programmes. But occasionally you might need to do some hard drive housekeeping.
One by one or series
To delete single recordings on your EE TV:
  1. 1
  2. 2
    go to RECORDINGS > ALL RECORDINGS and press OK
  3. 3
    pick the recording you want and press the delete button on your remote, then OK
  4. 4
    repeat for all recordings you want to delete
  5. 5
    you can also sort your recordings by date, channel, alphabet or category from OPTIONS
Delete all recordings
To delete all recordings from your recording settings:
  1. 1
  2. 2
  3. 3
    go to RECORDINGS > DELETE ALL and press OK
Recordings missing
Recordings missing
Sounds simple, but make sure your EE TV is always connected to a power supply and TV aerial. When it's off, it won't record your programmes.
Check your hard drive
To check for errors on your EE TV hard drive:
  1. 1
  2. 2
  3. 3
    go to ADVANCED SETTINGS, enter your PIN, then press OK on your remote to ENTER (if you've forgotten the PIN you chose when you set up your EE TV, get in touch)
  4. 4
    go to Check your hard drive > OK > CONTINUE > OK
  5. 5
    the check shouldn't take long, but you'll be unable to record, watch recordings or use Replay
  6. 6
    when you see Hard drive check is completed, wait a few seconds before checking your recordings
Reformat your hard drive
You can reformat your EE TV hard drive, but it will delete all your recordings and Replay content. To do this:
  1. 1
  2. 2
  3. 3
  4. 4
    go to Format your hard drive and press OK > CONTINUE > OK
  5. 5
    your EE TV hard drive will reformat
Reset EE TV
If you continue to have problems recording, it may help to restore your EE TV default settings.
Thanks for your feedback
Give us a call
Give us a call
Call now
150
Free to pay monthly
25p per call on pay as you go
Open
Closed
Bank Holiday Monday opening times: 08:00-20:00
Mon to Fri
Sat
Sun
Ask the Community
Ask the Community
Ask questions and share tips with other people 24 hours a day
Book an appointment
Book an appointment
You can book a phone appointment with one of our local experts.
Something went wrong. Please try again later We cannot identify your location. Please enter your postcode below
Finding you
Open Mon to Sat
Open Sun
Need more help
