What is EE TV?
In this article
EE TV allows you to watch great television at home or on your mobile.
How do I get EE TV?
How do I get EE TV?
From 27 June 2019, EE TV will no longer be available for new customers to purchase and EE Broadband customers won't be able to upgrade to a plan that includes EE TV.
If you're an existing EE TV customer nothing will change and you can continue to enjoy exactly the same service until it ends in March 2021. We'll be in contact with you well in advance of this date to advise you on what happens next and on your options.
Additionally, if you're an existing EE TV customer you can still upgrade and change your plan as normal. You also have the choice to keep EE TV if your broadband contract comes to an end or if fibre broadband becomes available in your area.
If you decide to leave EE TV, you won't be able to sign up to it again at a later date.
What can I watch on EE TV?
EE TV offers access to over 70 free channels with 11 in HD including BBC One HD, BBC Two HD, ITV HD, Channel 4 HD and Channel 5 HD. There is also access to on demand content and a range of subscription content providers including NOW TV and hayu.
What can I do with EE TV?
EE TV has a range of features on the EE TV box and via the EE TV app.
  1.
    Watch four different programmes at the same time
    Multiscreen lets you and your family watch live or recorded programmes on four different devices around your home at the same time.
  2.
    Record from your device
    You can set your EE TV box to record while you're out and about.
  3.
    Use your device as a remote control
    Use the EE TV app to browse programmes and plan your viewing. You can also control and manage your recordings via the EE TV app too.
  4.
    Flick and Fetch
    Move something you're watching in the EE TV app to your TV screen with a Flick of your finger. And if you need to leave the room, Fetch it from the TV by pressing the icon in your device's EE TV app menu.
  5.
    Pause, rewind, record
    You can record up to four programmes at once and you can store up to 600 hours of standard definition TV or 300 hours of HD.
  6.
    Replay
    Watch programmes broadcast during the last day on any of your eight favourite standard definition channels (or six HD channels).
  7.
    Restart
    Tuned in halfway through a programme? With Restart you can skip back to the beginning of the programme on your selected Replay channels.
  8.
    Create personal profiles
    Create your own personal TV guide on your device with the EE TV app.
  9.
    Watch with Twitter
    The Twitter icon in your EE TV guide shows you what's trending so you can watch the most talked-about programmes as they happen.
How do I set up EE TV?
EE TV is designed to be easy to set up and use. Once you've connected your EE TV box to your TV and router, you'll be able to follow the on screen instructions to finish your set up then scan for Freeview channels and download apps for on demand content.
> Find out more about how to set up EE TV
Do I need a TV aerial for EE TV?
Yes, we recommend you use a rooftop TV aerial in order to get your digital TV, radio channels and programme guide with EE TV. Alternatively, you could use an indoor aerial but the signal may not be strong enough to get all EE TV functions.
No rooftop aerial?
Find a registered fitter at getmedigital or CAI Trade Gateway.
How do I use the EE TV app with EE TV?
Once you’ve got EE TV installed, you can download the EE TV app from your device’s app store. You'll then be able to watch EE TV on your device, wherever you are.
You can also create your personal TV guide, search for content, manage recordings, Flick and Fetch, Replay programmes and watch live TV on the EE TV app.
> Find out more about how to use the EE TV app
How do I record TV shows on EE TV?
On EE TV you can record up to four programmes at once and you can store up to 600 hours of standard definition TV or 300 hours of HD TV on the EE TV box.
You can set up and manage recordings on the EE TV box and also through the EE TV app so you can even set your EE TV box to record while you're out and about.
Good to know:
You can change standard recordings that have been set up by anyone on the EE TV box but you can only change Recordings To Go from the device that set up the recording.
Can I view my photos and videos with EE TV?
Yes, there are a couple of ways to do this. You'll need to open the EE TV app, or tap the Home button if you're using the EE TV box, and then select My Photos & Videos.
If you're using the EE TV app and you've found the photo or video you want to view on your TV screen, flick your finger over your device's screen or select the Flick button.
Can I personalise EE TV?
Yes, you can create your own personal TV guide on your device via the EE TV app.
You'll be able to select your favourite shows, channels and recordings then be able to see them quickly and easily in the My TV section of the EE TV app.
Good to know:
A personal profile is unique to each device - if you have multiple devices you'll need to set one up on each device separately.
Thanks for your feedback
Give us a call
Give us a call
Call now
150
Free to pay monthly
25p per call on pay as you go
Open
Closed
Bank Holiday Monday opening times: 08:00-20:00
Mon to Fri
Sat
Sun
Ask the Community
Ask the Community
Ask questions and share tips with other people 24 hours a day
Book an appointment
Book an appointment
You can book a phone appointment with one of our local experts.
Something went wrong. Please try again later We cannot identify your location. Please enter your postcode below
Finding you
Open Mon to Sat
Open Sun
Need more help
