EE TV settings explained
In this article
You can find all your EE TV settings in the TOOLS & HELP section of your menu.
Open settings
Open settings
  1.
    Press MENU on your EE TV remote
  2.
    Use the arrows to go to TOOLS & HELP, then press OK
  3.
    Then go to SETTINGS and press OK
Information and status
  1.
    Guided tour – a short video tour of EE TV
  2.
    Contact us – all you need to get in touch with us
  3.
    Status – useful info about your EE TV and connection
  4.
    Licensing and copyright – terms, conditions and info on the GNU public licence
Network and connection
Shows which type of internet connection you're currently using.
You can also:
  1.
    change or set up a WiFi network
  2.
    connect via Ethernet
Advanced network settings – you'll only need these if you have an advanced home network which needs specific IP, DNS or proxy settings.
TV signal and quality
Shows how many TV channels and radio stations are available.
You can also:
  1.
    re-scan for more digital channels
  2.
    change your TV region
  3.
    view reception info
  4.
    do a manual scan
Replay
Replay
Change your Replay settings, including:
  1.
    REPLAY DURATION – set how long you can keep Replay programmes for. Or turn Replay off so you can record up to four programmes at once
  2.
    REPLAY GROUP – switch between HD (High Definition) or SD channels (Standard Definition). You can store more programmes on SD
  3.
    REPLAY CHANNELS – check and change your eight SD or six HD Replay channels. You can also filter the type of shows you want in Replay, like movies, drama or sport.
Recordings
Recordings
  1.
    see how many recordings you have and how many are scheduled
  2.
    add extra recording time to the start and end of your recordings (just to be on the safe side)
  3.
    cancel scheduled recordings
  4.
    delete all recordings
Multiscreen
Multiscreen
From the multiscreen menu you can:
  1.
    turn on your EE TV app user settings (so your EE TV box won't go to sleep in eco mode)
  2.
    see how many devices are paired with your EE TV box
  3.
    change your EE TV box name (the one you'll see when connected to your app)
Locks
Locks
  1.
    change your parental control settings
  2.
    modify your PIN
Accessibility
Accessibility
Turn on and change subtitles and audio description settings.
Sound and picture
Sound and picture
Change the HDMI video resolution for your TV, your audio output mode and also the video format.
Advanced settings
Advanced settings
  1.
    connect to our services to check your internet connection is working (our customer support team may ask you to do this)
  2.
    change idle time before standby
  3.
    check your hard drive – if you're having problems with Recording or Replay
  4.
    restore settings – if you're having problems with your EE TV
  5.
    format your hard drive – if you've run out of space or you're having problems with Recording, Replay or Restart
Thanks for your feedback
Give us a call
Give us a call
Call now
150
Free to pay monthly
25p per call on pay as you go
Open
Closed
Bank Holiday Monday opening times: 08:00-20:00
Mon to Fri
Sat
Sun
Ask the Community
Ask the Community
Ask questions and share tips with other people 24 hours a day
Book an appointment
Book an appointment
You can book a phone appointment with one of our local experts.
Something went wrong. Please try again later We cannot identify your location. Please enter your postcode below
Finding you
Open Mon to Sat
Open Sun
Need more help
