- This Adapter allows you the freedom to keep using your existing home phones when your service moves to Digital Voice or Digital Home Phone. If your current home phone is a DECT Cordless phone, with or without additional handsets, you will only need 1 Adapter. Suitable for residential lines only. If you only use Corded phones in your home, you will need an Adapter per phone. (You can have up to 5 Digital Voice products registered to the Smart Hub, this includes the Digital Voice Adapter)
Make the switch to Digital Home Phone or Digital Voice without having to replace the phones you already own. The EE Home Phone Adapter bridges your current handsets to the new digital service, so you can stay connected with minimal disruption and no unnecessary expense.
One Adapter covers all your cordless handsets
DECT cordless phone users will be pleased to know that just 1 Adapter covers the entire setup, including any extra handsets paired to the base unit. There's no need to purchase additional units for every room, keeping installation simple and cost-effective.
Corded phones need one Adapter each
If you use corded phones at home, each handset will need its own dedicated Adapter to connect to the Digital Home Phone service. This ensures every corded phone maintains a reliable connection with consistent call quality throughout your home.
Fits neatly into your Smart Hub setup
Up to 5 Digital Voice products can be registered to your Smart Hub at any one time and the Home Phone Adapter counts as 1 of those. This gives you the flexibility to build a fully connected home phone setup that works alongside your other Digital Voice tech.
Please note
The Adapter is suitable for residential lines only.
