Your Bright Box 2 supports:
- 2.4GHz (B,G and N) for maximum device compatibility and range
- 5GHz (N and AC) for better wireless performance and speed (on supported devices)
Wireless settings
To connect a computer or device to your Bright Box router, you'll need:
- Your wireless network name (also called an SSID), e.g. EE-1a2b3c or 5GHz-EE-1a2b3c
- Your wireless password (also called a security key or wireless network key)
You'll find these on a sticker on the bottom of your router and on your KEEP MEE card:
Connect your devices
To connect, simply:
- Open the wireless software on your computer or device
- Find and select your router's wireless network name
- If there's one starting 5GHz-EE, your device supports 5GHz wireless
- If not, use the one starting EE-...
- Select Connect or Join
- Enter your wireless password and connect
- Your device will now connect to your Bright Box 2
More help
You'll find more help in our guides below:
- Windows 10
- Windows 8
- Windows 7
- Windows Vista
- Windows XP
- Apple Mac
- PlayStation 4
- PlayStation 3
- Playstation Portable
- Xbox One
- Xbox 360
- iPhone
- iPad
- Amazon Kindle
- Nintendo Wii
- Android Tablet
- Android Mobile
- Smart TV
