Ireland add-ons from EE
  • EE
  • Orange
  • T-Mobile
The Ireland add-on is a monthly allowance of 500 minutes for:
  • making calls from the UK to standard landlines or mobile numbers in the Republic of Ireland
  • making calls from Ireland to standard landlines or mobile numbers in the UK
  • making calls to standard landlines or mobile numbers in Ireland when in Ireland
  • receiving calls when in Ireland
Once you’ve used up the inclusive minutes , you’ll be charged our standard rates for calls as set out in the Non-Standard Price Guide.
If you have an EE Extra Plan, the following call types are already included in your plan:
These call types will be deducted from your Extra Plan allowance and only calls from the UK to Ireland as described above will be deducted from your add-on.
Calls to premium rate numbers and other non-geographic numbers (which can vary over time) are not included. The maximum call length on these plans is 120 minutes after which time, you must redial to continue the call.
How to get the Ireland add-on
To buy an Ireland add-on, simply text 500IRE1 to 150.
Was this article helpful?
Thank you.
Thank you.
Thank you.
Thank you.
Getting the most from EE
Services and offers we have for you
