- well ventilated
- raised up from the floor
- away from other electronics
- near a plug and a window
- relatively close to your hub
Set up Smart Hybrid Connect without using the EE app
Set up using ethernet
- Check your Smart Hub is powered on (the light in the middle will be solid aqua or blue)
- Find the ethernet cable with yellow ends. You'll find one in the box from your Smart Hybrid Connect cable.
- Attach one end of the cable to the back of your Smart Hybrid Connect device.
- Attach the other to the back of your Smart Hub, using one of the yellow ethernet ports.
- Put your Smart Hybrid Connect close to your Smart Hub and plug it in.
- Turn on your Smart Hybrid Connect by pushing the power button.
- After a few seconds, the light in the middle of the Smart Hybrid Connect will flash green.
- Wait for the light to turn solid aqua or blue; that means it's paired with your Smart Hub. This can take up to 5 minutes.
- Check if your Smart Hybrid Connect is picking up a decent signal. When the 4G signal bars turn aqua or blue, your Smart Hybrid Connect has a strong signal (two or three bars is good).
- If your 4G signal isn't strong enough, try moving your device to another spot.
- Once your Smart Hybrid Connect is paired with your Smart Hub (showing a solid blue or aqua light), you can remove the ethernet cable.
- Move your Smart Hybrid Connect to a good location for 4G signal. This is so it can use the WiFi to work properly after using the ethernet cable.
Set up wirelessly
- Plug your Smart Hybrid Connect’s power cable into a power socket, in a spot that’s close to your Smart Hub.
- Press the WPS button on the back of the Smart Hybrid Connect and then the WPS button on the side of your hub. Press both buttons within 2 minutes of each other.
- Wait for the light to turn solid aqua or blue; this means it's paired with your Smart Hub. This can take up to 5 minutes.
- Check if your Smart Hybrid Connect is picking up a decent signal. When the 4G signal bars turn aqua or blue, your Smart Hybrid Connect has a strong signal (2 or 3 bars are good).
- Once your Smart Hybrid Connect is paired with your Smart Hub (showing a solid blue or aqua light), you can move your Smart Hybrid Connect to a good location for 4G signal.
If you have BT Hybrid Connect, get help with setting it up.
If your 4G signal is weak
If you’ve set up Smart Hybrid Connect and your 4G signal isn’t strong enough, try moving your device to another spot.
Your Smart Hybrid Connect is best placed:
What the lights on your Smart Hybrid Connect device mean
The lights on the device will tell you when you’ve found a good spot.
The central light should be aqua and the 4G signal bars aqua or white. This means your Smart Hybrid Connect device is connected to your Smart Hub using WiFi, and also to the mobile network.
If the central light turns red then try another location and restart the device.
Central light
Solid green
Your device is starting up.
Solid orange
Your device is too far from your hub.
Solid aqua
Your device is paired with your hub.
Solid red
There’s a problem, please restart your device. If it’s still red, get in touch.
Flashing green
Your Smart Hybrid Connect device is not paired with your Smart Hub. Make sure the hub’s on and attached to your device.
Flashing red
Your device cannot connect to your hub. Try connecting with an Ethernet cable or moving it closer.
Flashing aqua
Your device is pairing with the hub.
4G signal bars
Flashing aqua
Your device is connecting to the mobile network.
Solid aqua
Your device has a strong signal. Two or three bars are good.
Partially aqua
One bar is ok but you may be able to improve it. Follow the instructions in the earlier section
Solid white
Your device is using mobile data to support your broadband. Two or three bars are good.
Partially white
One bar is ok but you may be able to improve it. Follow the instructions in the earlier section.
Solid red
There’s a problem with your device. We’d like to help, so please get in touch.
Connection speed with Smart Hybrid Connect
Smart Hybrid Connect uses the EE mobile network to give you a connection of up to 30 Mbps (download speed) and 5 Mbps (upload speed). It might be a bit faster or slower depending on your Smart Hybrid Connect's mobile signal and how busy the network is.
If your connection is slow, try moving your Smart Hybrid Connect to a different spot.
