Data usage and add-ons for 4GEE WiFi
  • Go to section
You can easily manage your 4GEE WiFi device and add or remove add-ons online through My EE.
Pay monthly add-ons
Pay monthly add-ons
We’ll text you if you use up your allowance, but you can easily get back to making calls, sending texts or going online by buying a data or roaming add-on.
How to buy data add-ons on your 4GEE device
Make sure you're connected to the 4G network then:
    open your browser and go to add-on.ee.co.uk
    under purchase, select the data add-on you want to buy, activate it and start browsing
The cost of the add-on will be added to your pay monthly bill. This will appear on your next bill as a one-off charge. You can view your bill, including any additional purchases, in My EE .
Roaming add-ons
Roaming add-ons
Things to know about using data overseas:
    if you’re outside the UK but inside the EU (including Jersey, Guernsey, the Isle of Man and Switzerland) you can use your 4GEE WiFi device or tablet allowances to get online for no extra cost
    make sure data roaming is enabled on your device (find help on how to do this)
    if you're outside the EU, the internet won’t work on your device unless you have an active roaming add-on
How to buy a roaming add-on (before you travel)
    log in to My EE  and go to Menu > Plan & add-ons
    go to Add-on > Buy add-ons
    Select the add-on you want, then buy
Online
If you’re on 4G you can also use our website to buy roaming add-ons.
How to buy a roaming add-on (while you’re away)
    open your browser and you’ll be connected to a page showing available add-ons
    select the data add-on you'd like to buy. The cost of the add-on will be added to your pay monthly bill. This will appear on your next bill as a one-off charge
Over the phone
If you need to talk to us while you’re away, call us on +44 7953 966 250.
Managing your costs and usage
You can estimate any costs or data add-ons you might need while abroad with our roaming tool  or you can check your current usage at any time at add-on.ee.co.uk , in the My EE app  or by logging in to My EE .
Add-ons price guides
Price guides
> Download our pay monthly data add-ons price guide PDF
> Download our pay as you go data add-ons price guide PDF
> Download our roaming add-ons price guide PDF
> Download the full 4GEE WiFi terms and conditions
Pay as you go add-ons
Data add-ons
Make sure you're connected to the 4G network, then:
    open the browser on your device or tablet and go to add-on.ee.co.uk
    under purchase, select the data add-on want
    the cost of the add-on will be taken from your top up balance, if you don't have enough credit, top up now
Managing your usage
It's impossible to go over your data limit. If your data runs out, you can buy an add-on. You can check your data usage at any time in the My EE app or by logging in to My EE.
Roaming add-ons
Roaming add-ons
Over the phone
Using your 4GEE WiFi device abroad
First, check that roaming is enabled before you go. For 4GEE devices you can do this in your Connection Manager.
Connect using Car WiFi
    go to Connection Manager or type http://192.168.1.1  into your browser
    log in and go to Settings > Dial up  > Mobile connection
Then you will have two options:
    manual – your device will only connect to the internet when you click ‘connect’
    automatic – your device automatically connects to the internet when it’s switched on. For ease when roaming select automatic
Tablets
You can change your roaming settings in your tablet settings.
Give us a call
Give us a call
Call now
150
(Free - 25p per call on PAYG)
Open
Closed
Mon to Fri
Sat to Sun
Ask the Community
Ask the Community
Ask questions and share tips with other people 24 hours a day
Find a store
Find a store
Something went wrong. Please try again later We cannot identify your location. Please enter your postcode below
Finding you
Open Mon to Sat
Open Sun
Need more help
Last updated: 18/12/2017
Nikki posted this article. Got a comment? Good or bad, we'd be pleased to hear from you.
Was this article helpful?
  • Select a reason
  • The article is too long
  • The article doesn't make any sense
  • Other
0/600
Thank you.
Glad to hear it.
Thank you.
Glad to hear it.
Getting started on 4GEE WiFi
How do I make payments and top up my 4GEE WiFi?
