Can I use powerline adaptors with EE TV?
  • Go to section
Powerline adaptors are great if your EE TV box and router are too far apart to get a good WiFi connection. With powerline adaptors, you use the mains electric circuits of your house to carry the internet signal between the two adaptors.
You can use your own or get them from us >
How to set up your powerline adaptors
  • 1
    Connect one end of the Ethernet cable that came with your powerline adaptors into a yellow socket on your Bright Box router
  • 2
    Connect the other end to one of your powerline adaptors
  • 3
    Plug the powerline adaptor into a mains socket and switch on
  • 4
    Next, attach the other Ethernet cable to your EE TV and the second powerline adaptor
  • 5
    Plug the powerline adaptor into another mains socket and switch the socket on
  • 6
    After a few seconds, the PWR (power) light will stop flashing and show as a continuous light
  • 7
    Press and hold the Pair button on one of the adaptors for more than one second and less than four seconds
  • 8
    Repeat the process with the second adaptor within two minutes
  • 9
    The PLC indicator will blink first, then the light will turn off and show as a steady light
  • 10
    Your adaptors are now set up
Give us a call
Give us a call
Call now
Free - 25p per call on PAYG
Mon to Fri
Sat to Sun
Ask the Community
Ask the Community
Ask questions and share tips with other people 24 hours a day
Find a store
Find a store
Something went wrong. Please try again later We cannot identify your location. Please enter your postcode below
Finding you
Open Mon to Sat
Open Sun
Need more help
Last updated: 9/1/2018
Sharelle posted this article. Got a comment? Good or bad, we'd be pleased to hear from you.
Was this article helpful?
  • Select a reason
  • The article is too long
  • The article doesn't make any sense
  • Other
Thank you.
Glad to hear it.
Thank you.
Glad to hear it.
Connect to EE TV using wireless
EE TV settings explained
