How can I change my TV region and PIN on EE TV?
  • Go to section
To change your TV region:
  • 1
    Press MENU on your EE TV remote
  • 2
    Use the arrow buttons to go to TOOLS & HELP and press OK
  • 3
    Go to SETTINGS > TV SIGNAL & QUALITY > TV Region
  • 4
    If other TV regions are available in your area, you’ll be able to switch
Good to know
If you change your TV Region and use Replay, press the right arrow on your remote to check your REPLAY settings
To change your PIN:
To change your PIN:
If you've forgotten your PIN, we'll be happy to help. Just get in touch >
If you'd like to change your PIN, you can do this from your LOCKS settings:
  • 1
  • 2
  • 3
    Go to SETTINGS > LOCKS and enter your PIN
  • 4
    Select Modify PIN and enter a new memorable PIN
  • 5
    To return to the home screen, press MENU twice
Give us a call
Give us a call
Call now
150
(Free - 25p per call on PAYG)
Open
Closed
Mon to Fri
Sat to Sun
Ask the Community
Ask the Community
Ask questions and share tips with other people 24 hours a day
Find a store
Find a store
Something went wrong. Please try again later We cannot identify your location. Please enter your postcode below
Finding you
Open Mon to Sat
Open Sun
Need more help
Last updated: 16/1/2018
Sharelle posted this article. Got a comment? Good or bad, we'd be pleased to hear from you.
Was this article helpful?
  • Select a reason
  • The article is too long
  • The article doesn't make any sense
  • Other
0/600
Thank you.
Glad to hear it.
Thank you.
Glad to hear it.
Using your EE TV remote control
How do I update my EE TV set top box software?
