EE TV settings explained
  • Go to section
You can find all your EE TV settings in the TOOLS & HELP section of your menu.
Open settings
Open settings
    Press MENU on your EE TV remote
    Use the arrows to go to TOOLS & HELP, then press OK
    Then go to SETTINGS and press OK
Information and status
    Guided tour – a short video tour of EE TV
    Contact us – all you need to get in touch with us
    Status – useful info about your EE TV and connection
    Licensing and copyright – terms, conditions and info on the GNU public licence
Network and connection
Shows which type of internet connection you're currently using.
You can also:
    change or set up a WiFi network
    connect via Ethernet
Advanced network settings – you'll only need these if you have an advanced home network which needs specific IP, DNS or proxy settings.
TV signal and quality
Shows how many TV channels and radio stations are available.
You can also:
    re-scan for more digital channels
    change your TV region
    view reception info
    do a manual scan
Replay
Replay
Change your Replay settings, including:
    REPLAY DURATION – set how long you can keep Replay programmes for. Or turn Replay off so you can record up to four programmes at once
    REPLAY GROUP – switch between HD (High Definition) or SD channels (Standard Definition). You can store more programmes on SD
    REPLAY CHANNELS – check and change your eight SD or six HD Replay channels. You can also filter the type of shows you want in Replay, like movies, drama or sport.
Recordings
Recordings
    see how many recordings you have and how many are scheduled
    add extra recording time to the start and end of your recordings (just to be on the safe side)
    cancel scheduled recordings
    delete all recordings
Multiscreen
Multiscreen
From the multiscreen menu you can:
    turn on your EE TV app user settings (so your EE TV box won't go to sleep in eco mode)
    see how many devices are paired with your EE TV box
    change your EE TV box name (the one you'll see when connected to your app)
Locks
Locks
    change your parental control settings
    modify your PIN
Accessibility
Accessibility
Turn on and change subtitles and audio description settings.
Sound and picture
Sound and picture
Change the HDMI video resolution for your TV, your audio output mode and also the video format.
Advanced settings
Advanced settings
    connect to our services to check your internet connection is working (our customer support team may ask you to do this)
    change idle time before standby
    check your hard drive – if you're having problems with Recording or Replay
    restore settings – if you're having problems with your EE TV
    format your hard drive – if you've run out of space or you're having problems with Recording, Replay or Restart
Give us a call
Give us a call
Call now
150
(Free - 25p per call on PAYG)
Open
Closed
Mon to Fri
Sat to Sun
Ask the Community
Ask the Community
Ask questions and share tips with other people 24 hours a day
Find a store
Find a store
Something went wrong. Please try again later We cannot identify your location. Please enter your postcode below
Finding you
Open Mon to Sat
Open Sun
Need more help
Last updated: 16/1/2018
Sharelle posted this article. Got a comment? Good or bad, we'd be pleased to hear from you.
Was this article helpful?
  • Select a reason
  • The article is too long
  • The article doesn't make any sense
  • Other
0/600
Thank you.
Glad to hear it.
Thank you.
Glad to hear it.
Can I use powerline adaptors with EE TV?
EE TV lights explained
