How can I test my broadband speed?
  • Go to section
Think your broadband’s running a little slow? Here’s how you can test your browsing speed
When should I run a test?
If you think your connection is running slower than it should and there aren’t any wider problems with broadband in your area:
> Check for known connection problems in your area
To run a test, make sure your router’s connected to your home’s master socket (it’ll look like one of the sockets in the pictures below).
1. Disconnect your device from WiFi and connect it directly to your router using an Ethernet cable
2. Shut down any devices that might be using your connection (including smart TVs and mobile phones)
3. Open the BT Wholesale Broadband Performance Test (it only works if you have Flash installed – if none of your devices support Flash, use Speedtest by Ookla instead)
4. Click the Yes tick box and the Begin Test button to test your speed
5. Once complete, the site will show the results of your download and upload tests
What does my test result mean?
Your test result will show a download speed and an upload speed (see below). Ignore the ping latency.
Compare your result with your estimated speed
To see if your speeds are slow, you need to compare results with the estimated speed you should be getting.
> Find the estimated speed for your postcode
My test speed is lower than my estimated range
If you tested with a WiFi connection, first try connecting your device directly to your router with an Ethernet cable and try the test again.
If you were using a wired connection the first time, find out how to improve your broadband speed.
My test speed is within my estimated range
There are still a couple of things you can try to speed things up:
If your device was connected to a WiFi network during the test, find out how to improve your wireless speed.
If you were using a wired connection during the test:
    restart your router
    try a second test with another device to check the problem’s not with the device you used for the first test
    switch off peer-to-peer services (such as BitTorrent) as these can hog a lot of bandwidth
If your problem still isn’t solved, please get in touch.
My test speed is lower than my minimum guaranteed speed
    click 'Run further diagnostics' on the test and enter your phone number. This will log your test on our system and our team will investigate
    still slow? Get in touch >
Please note: You have the right to cancel if our diagnostics show that you’re not getting the minimum guaranteed speed.
Give us a call
Give us a call
Call now
150
(Free - 25p per call on PAYG)
Open
Closed
Mon to Fri
Sat to Sun
Ask the Community
Ask the Community
Ask questions and share tips with other people 24 hours a day
Find a store
Find a store
Something went wrong. Please try again later We cannot identify your location. Please enter your postcode below
Finding you
Open Mon to Sat
Open Sun
Need more help
Last updated: 8/1/2018
Mark posted this article. Got a comment? Good or bad, we'd be pleased to hear from you.
Was this article helpful?
  • Select a reason
  • The article is too long
  • The article doesn't make any sense
  • Other
0/600
Thank you.
Glad to hear it.
Thank you.
Glad to hear it.
Internet speeds explained
How can I improve my broadband speed?
