How much does it cost to share my data connection?
  • Go to section
Tethering is included in your plan as part of your data allowance.
When you tether a laptop or tablet to your phone, the online data it uses comes out of your data allowance.
If you go over your plan's allowance, we'll charge you for data at the standard rate.
Making calls while you're tethering
If you're using the 3G or 4G network, you can make calls on your mobile phone and use tethering at the same time.
If you're using the 2G network, your tethering session will be stopped when you make a phone call.
Turning off tethering
It's a good idea to turn tethering off on your phone when you've finished. This can help you avoid any unexpected data charges.
iPhone
  • 1
    Open your iPhone menu.
  • 2
    Go to General > Network
  • 3
    Tap Internet Tethering to switch it off.
Android
  • 1
    Open your phone's menu.
  • 2
    Go to Settings > Wireless & Networks
  • 3
    Open Portable WiFi hotspot to switch tethering off.
Settings may differ slightly on different Android devices.
Give us a call
Give us a call
Call now
150
(Free - 25p per call on PAYG)
Open
Closed
Mon to Fri
Sat to Sun
Ask the Community
Ask the Community
Ask questions and share tips with other people 24 hours a day
Find a store
Find a store
Something went wrong. Please try again later We cannot identify your location. Please enter your postcode below
Finding you
Open Mon to Sat
Open Sun
Need more help
Last updated: 8/1/2018
Andrew posted this article. Got a comment? Good or bad, we'd be pleased to hear from you.
Was this article helpful?
  • Select a reason
  • The article is too long
  • The article doesn't make any sense
  • Other
0/600
Thank you.
Glad to hear it.
Thank you.
Glad to hear it.
How do I share my device's data connection?
