Listening to radio on EE TV
Did you know you can listen to digital radio on your EE TV? The easiest way to choose your radio station is from the RADIO menu.
Using the RADIO menu
  1. Press the MENU button on your remote
  2. Use the down and right arrows on your remote to highlight RADIO
  3. Press OK
  4. The RADIO menu will open
  5. Use the up, down, left and right arrows to highlight the channel you want to listen to
  6. Your radio station will play
  7. You can also press OK to load the radio screen
  8. If interactive content is available, you can open by pressing the red button on your remote
Changing channel
You can change channel by returning to your RADIO menu or while listening to radio:
  1. Press the up arrow on your remote - the channel wall menu will open
  2. Use the up and down arrows to select the radio programme you want to listen to
  3. Press OK to select
Was this article helpful?
Thank you.
Thank you.
Thank you.
Thank you.
