Testing your broadband speed
Think your broadband’s running a little slowly? We’re here to show you how to test the speed you’re browsing at.
When should I run a test?
If you think your connection is running slower than it should and there aren’t any wider problems with broadband in your area.
Check for known connection problems in your area >
community help speech bubble
Not found your answer?
Find it in the EE Community
Was this article helpful?
Thank you.
Thank you.
Thank you.
Thank you.
