Help with signal box
In case you experience any problems with your Signal Box, we've got the following advice to help.  Or you can also learn more about how to set up and use your Signal Box
Changing broadband or moving home
If you change your home broadband supplier, router or move house then the Signal Box will stop working and the green light will flash quickly. You'll need to call customers services to get it re-activated. This is just security feature to help us prevent fraud.
If you're an Orange customer call 0800 079 0275
If you're an EE customer call 150
If you're a T-Mobile customer call 0800 956 3146
Poor call quality
If you have a slow internet connection, and other people in the house are using the internet at the same time as you're making a call, the call quality can sometimes be poor. This is because your internet connection can only process a certain amount of data and information at any one time.
Green light flashing quickly
Sometimes your Signal Box may lose connection with us. It's worth unplugging it and then re-connecting it again, leaving it for a few hours to rectify itself. If the problem persists, call customer services.
Red light - single flash
This means that Signal Box isn't connected properly. Check the cables are plugged in correctly to the router and your Signal Box. If this doesn't work, try changing the Ethernet cable and leave it for a couple of hours to reset before giving us a call.
Red light - sequence of two flashing lights
The Signal Box is not receiving an internet connection. Check the connection of your home broadband.
Red light - sequence of three flashing lights
Something else is interfering with the signal. Make sure the Signal Box is at least 60cm away from the router and check it's not too close to other electrical equipment.
n.b. the Signal Box is not compatible with the Galaxy Core Prime and the Xcover 3
Was this article helpful?
Thank you.
Thank you.
Thank you.
Thank you.
GETTING THE MOST FROM EE
Services and offers we have for you
New to EE? Use our get started guides
Follow our step-by-step guides to help you get up and running with EE.
Discover more with our video guides
Watch our help and support videos to get the most out of EE and your phone.
Manage your account with My EE app
Keep track of your usage, manage your add-ons or pay your bill on the move.
Join the EE Community now
See what people are saying in the EE Community - get involved or get advice.
