Bright Box 2 Wireless Router - change wireless channel
Your neighbour's WiFi, computers, microwave ovens, baby monitors and all your lovely gizmos give off signals that can affect your wireless connection. Not good. Changing the channel or frequency on your Bright Box 2 can help fix the problem. There's a few solutions you can try:
Swap to 5GHz
Your Bright Box 2 supports both 5GHz and 2.4GHz wireless - sometimes called dual-band. 5GHz is (generally) less crowded, so you'll get less interference from other devices.
Swapping is easy - simply connect to the wireless network starting 5GHz-EE...
Bright Box 2 - image of sticker found on base of router
If you can't see the 5GHz-EE... network, try moving closer to your router, or consider upgrading your wireless device.
Intelligent wireless
When you turn on your Bright Box 2, it looks for and uses the best WiFi channel it can find. This helps reduce problems caused by interference, giving you the best wireless connection.
You can also re-check by pressing the Intelligent Wireless button. You'll find this on the top of your Bright Box 2.
Intelligent Wireless button on the top of the Bright Box 2
Change your channel from the admin pages
You can also change your wireless channel from your Bright Box 2 admin pages. To do this:
  1. From a computer connected to your Bright Box, go to 192.168.1.1 (opens in a new tab or window)
    Enter 192.168.1.1 into browser address bar
  2. The router's LOGIN SCREEN will open
    Router's admin pages
  3. Enter the username and password for the admin pages
    - The username is admin (all lower case)
    - The password can be found on a sticker on the bottom of your router
    Bright Box 2 sticker
  4. Select LOGIN
    Enter the username and password for the router's admin pages
  5. The STATUS page will open
    Status page
  6. Select BASIC from the menu
    Select Basic from the EE menu
  7. Select Wireless Settings
  8. The WIRELESS SETTINGS page will open
  9. From here, you can change the channel for your 2.4GHz and 5GHz wireless networks
2.4GHz network
Wireless network name starting EE-.....? - Follow these steps:
  1. In the Channel menu, select a number from 1 - 11 - you can choose 12 or 13, however some wireless devices don't like these channels
    Channel menu open - channel 6 highlighted as an example
  2. Click SAVE SETTINGS
    Click SAVE SETTINGS
  3. Your settings will be applied
    Applying changes. Please wait. The process may take up to 30 seconds. If you are making wireless changes you may need to reconnect to the wireless network.
  4. You'll be taken back to the WIRELESS SETTINGS page.
  5. You may need to re-connect to your Bright Box 2 after making the change.
5GHz network
Wireless network name starting 5GHz-EE-.....? - Follow these steps:
  1. Select a new channel from the Channel menu
    Channel menu open - channel 52 highlighted as an example
    Click SAVE SETTINGS
  4. You'll be redirected back to the WIRELESS SETTINGS page
Was this article helpful?
Thank you.
Thank you.
Thank you.
Thank you.
Getting the most from EE
Services and offers we have for you
