Techicolor TG589 router - Backing up your configuration
Once you’ve configured your Techicolor TG589 router to your needs, it is recommended to back up your configuration for later use. This way you can always return to your working configuration in case of problems.
  1. Browse to your Techicolor TG589 router web interface.
  2. Select Gateway. The Gateway page appears.
  3. Choose Export.
  4. Browse to the Techicolor TG589 router web interface.
  5. The Techicolor TG589 router prompts you to save your backup file. Do not change the file extension.
  6. Save your file to a location of your choice. Do not edit the backup files as this may result in corrupt files making them worthless as configuration backup.
Restoring your configuration
  2. Choose Gateway. The Gateway page appears.
  3. Under Import Configuration, click Browse, open your backup file and then select Import.
    -    Backup files usually have .bin as extension.
  4. The Techicolor TG589 router restores your configuration.
  5. The Techicolor TG589 router restarts.
Was this article helpful?
Thank you.
Thank you.
Thank you.
Thank you.
Getting the most from EE
Services and offers we have for you
