WiFi Calling set up Samsung Galaxy S6 and S6 Edge
  • EE
  • Orange
  • T-Mobile
This article explains how to set up WiFi Calling on the Samsung Galaxy S6 and Samsung Galaxy S6 Edge. Just follow the three simple steps below to get started.
1.            Activate WiFi Calling
If you haven't already done so, text WiFi Calling to 150 from your EE phone.
2.            Connect your phone to WiFi
Not sure how? Read our instructions.
3.            Switch WiFi Calling on
Tap Settings from the dropdown menu. Scroll down to the Call icon and tap. Scroll down until you see WiFi Calling and then tap the box next to it. A pop-up will appear asking to confirm if you want to enable WiFi Calling. Tap ok. WiFi Calling will now appear with a green tick in the Settings menu. A WiFi Call indicator will appear at the top of your screen. You’re now ready to send and receive calls and text over WiFi.
Was this article helpful?
Thank you.
Thank you.
Thank you.
Thank you.
