Seamless speed and responsiveness
Faster wireless connections
WiFi 7 delivers up to 46 Gbps of theoretical speed—almost 5× more than WiFi 6 at 9.6 Gbps—bringing wireless performance closer to your broadband speed.
Lower latency for smoother activities
With Multi-Link Operation, WiFi 7 reduces lag for gaming, video calls, and live streaming by intelligently switching traffic across multiple bands.
Need to know
Your router’s WiFi performance doesn’t change your broadband download/upload speeds; it simply delivers your internet more effectively throughout your home.
How it works: reliability and capacity
WiFi 7 builds on WiFi 6 with smart improvements to better handle busy homes:
Increased bandwidth
Think of WiFi 7 as adding extra lanes to your network motorway - fewer slowdowns, even with many devices connected.
Smart band selection
The network actively chooses the best band (2.4 GHz, 5 GHz, or 6 GHz) and seamlessly switches to maintain stable connections.
Why upgrade?
Stronger coverage across your home
Get consistent WiFi speeds even in rooms far from the router, thanks to WiFi 7’s advanced signal capability.
Built for modern home life
Ideal for households with multiple gamers, streamers, smart devices, and frequent videoconferencing.
Future-proof setup
Even if your devices aren’t yet WiFi 7-capable, they’ll still benefit from the new hub's improved performance.
Choosing your EE Smart Hub
Smart Hub 7 Pro (Tri-band)
Best for large households or heavy usage - supports 2.4 GHz, 5 GHz, and 6 GHz simultaneously to reduce interference and boost performance.
Smart Hub 6 Plus (Dual-band)
Ideal for smaller homes, it covers 2.4 GHz and 5 GHz bands, offering a balance of speed and simplicity at a lower cost.
Find out more about the Smart Hub 6 Plus
To upgrade to one of these hubs, review our Broadband plans and select the plan that suits you.
