Netflix as an Inclusive Extra
Netflix lets you stream your favourite shows and films on your phone, tablet or TV.
What's included
Netflix is a streaming service with a wide range of TV series, films and original content. You can watch using the Netflix app on compatible devices.
With your subscription, you get:
  • a choice of plans to suit how you watch
  • access across multiple devices
  • personalised recommendations and profiles
Netflix planWhat you getMobile plan
Standard with advertsWatch in HD on up to 2 devices in the same household, with a few adverts.Included with All Rounder. Upgrade to Standard or Premium available.
StandardWatch in HD on up to 2 devices in the same household.All Rounder customers can pay to upgrade.
PremiumWatch in HD or Ultra HD on up to 4 devices in the same household.Included with Full Works. All Rounder customers can pay to upgrade.
Get Netflix as an Inclusive Extra
You can get Netflix through EE as an Inclusive Extra when you have our Full Works or All Rounder plan. The subscription available to you is depedent on your plan:
  • All Rounder - Netflix Standard with adverts
  • Full Works - Netflix Premium
Upgrading your Netflix subscription
If you have Netflix Standard with Adverts, you can also upgrade to Netflix Standard or Netflix Premium.
How to add, upgrade or remove Netflix
Need to know
If you’ve already got an account, use the same email address when you activate it. This makes sure your billing moves to EE.
Once activated, your existing account stays the same and your billing moves to your EE bill
If you leave EE, your Netflix subscription will continue and payments will go back to your previous payment method.
If your Netflix subscription is through another provider, make sure to let them know. They will need to cancel it, otherwise, you may keep getting charged.
previous
next
  1. Select Manage.
  2. Select Mobile and SIMs.
  3. Select Add-ons and Extras.
  4. Add, upgrade or remove Netflix using the Your Inclusive Extra section.
Once added, we'll send you a text. Open the link in the message and follow the instructions. The link is valid for 7 days.
The legal bit
Was this article helpful?
Thank you for your feedback!
Sorry about that! Why didn’t this article help you?
