Set up your Smart Hub Plus by following the instructions in the EE app.
Your hub might need to update its software. It usually takes around 20 minutes, but it can sometimes take up to 1 hour. Don’t restart your hub until the update is complete.
- download from the App Store if you're an Apple user
- download from Google Play if you're on Android
