Fix a broadband problem
Fix WiFi connection issues with your Smart Hub
About broadband speeds
Fix WiFi signal issues
Fix a problem with EE WiFi Extender
What the lights on your EE Smart Hub mean
How to check your broadband speed
Help connecting devices to your hub
Fix an EE Broadband connection problem
Fix an EE Connectivity Backup problem
What the Openreach modem lights mean
Check your Full Fibre wiring and set up
Restart your Openreach modem
Can’t find what you’re looking for?
