Mobile WiFi Extender 7 Pro
This article provides instructions on setting up, managing, and placing your Mobile WiFi Extender 7 Pro device. It also has information about spare parts, a downloadable user guide, and who to contact for help.
About the Mobile WiFi Extender 7 Pro
Mobile WiFi Extender 7 Pro extends your existing Smart 5G Hub network, ensuring consistent WiFi coverage throughout your home.
Mobile WiFi Extender 7 Pro compatibility
  • compatible with Smart 5G Hub/Smart 5G Hub 7 Pro (HH70C) and Smart 5G Hub 7 Plus (HH72C)
  • compatible with Smart 5G Hub Model HH20C - extender backhaul will operate in WiFi 6E mode.
  • not compatible with any fixed EE Broadband Hubs or Smart 4G Hub.
Buy Mobile WiFi Extender 7 Pro
Set up your Mobile WiFi Extender 7 Pro
Wireless Setup
Turn on your Mobile WiFi Extender 7 Pro
  • plug your Mobile WiFi Extender 7 Pro into a socket near your hub
  • switch on the extender and wait for the light to flash red
Pair with your Hub
  • Press the WPS button on your hub, then within two minutes press the WPS button on the back of your extender.
  • Pairing may take a few minutes. When the hub and extender have paired, the light on the front of the extender will be solid aqua.
Wired setup
Plug your Mobile WiFi Extender 7 Pro into your hub
  • Plug one end of the white ethernet cable we’ve supplied into one of the yellow LAN ports on the back of the Mobile WiFi Extender 7 Pro.
  • Plug the other end into a spare yellow LAN or yellow LAN/WAN port on the hub. Ensure your hub is turned on.
Wait for a solid aqua light
  • Turn on the Mobile WiFi Extender 7 Pro. After a few minutes, the light on the front of the extender should turn solid aqua, indicating it has successfully paired with the hub.
Positioning your Mobile WiFi Extender 7 Pro
Try positioning your Mobile WiFi Extender 7 Pro halfway between your hub and the area with poor WiFi. A solid aqua light indicates a good signal.
If the light is orange, try moving the extender to a different location.
What the lights on your Mobile WiFi Extender 7 Pro show
Colour on the front of the hubWhat it means
A flashing Green LEDFlashing Green
Your device is starting up. Wait at least 3 minutes for it to turn Aqua.
A flashing blue LEDFlashing Blue
You’ve activated WPS to connect to your Hub, a wireless device, or extender. Connect within 120 seconds.
Blue
Your Mobile WiFi Extender 7 Pro has successfully connected. Once it turns Aqua, you’re ready to go.
Aqua
Your Mobile WiFi Extender 7 has a successful connection and a good signal over WiFi or Ethernet.
A solid Orange LEDOrange
Your Extender is connected, but the signal is poor. Try moving it closer to your hub or another extender.
A flashing Red LEDFlashing Red
Your extender is not connected to your hub. Follow the instructions in the guide to set up your extender. You can also reset it to factory settings by pressing the reset button on the end of a paper clip for five seconds.
A solid Red LEDRed
Turn your extender off and on again. If the light still doesn’t turn aqua, use the end of a paper clip to press the extender reset button for five seconds.
Managing your Mobile WiFi Extender 7 Pro
Changing your WiFi settings
  • open a web browser window
  • enter http://192.168.1.1 into the address bar
  • select Log in and enter your admin password - found on the label on the base of your Smart 5G Hub or the Keep Me Card, which came with your hub
  • you can now change your SSID (WiFi network name), password and other network settings
Resetting your Mobile WiFi Extender 7 Pro to factory defaults
If you’re having issues, factory resetting your device by pressing the reset button on the back for five seconds may solve the problem.
After factory resetting the extender, you must pair it with your hub again.
Documents
You will need Adobe Reader to view PDF documents.
Product help information
Need help with this product? Contact us.
Was this article helpful?
Thank you for your feedback!
Sorry about that! Why didn’t this article help you?
