How do I use Replay and Restart with EE TV?
  • Go to section
Never miss a programme, with the Replay and Restart features on EE TV.
Using Replay and Restart
When you first set up your EE TV, you chose to either use Replay to watch programmes you’ve missed on selected channels, or do without Replay and record up to four channels.
  1.
    Replay lets you record anything that has been on your eight favourite standard definition (SD) channels or six HD channels during the last day. You'll also be able to record up to two programmes at the same time
  2.
    Restart is available when you have Replay turned on. So, if you tune in halfway through a programme, you can skip back to the beginning
  3.
    save Replay lets you save programmes available for Replay so you can watch them later
REPLAY menu
You'll find REPLAY in your EE TV menu.
  1.
    press MENU on your EE TV remote
  2.
    go to REPLAY and choose a recommended programme
  3.
    select ALL REPLAY to browse through your Replay channels
  4.
    in OPTIONS you can also sort your content so it displays by category or alphabetically
  5.
    anything you'd like to keep, just press REC on your remote
TV Guide
You can watch Replay TV from your TV Guide.
  1.
    press GUIDE on your remote
  2.
    browse to one of your Replay channels – you’ll find a Restart icon to help remind you
  3.
    move to the left to find content available for replay and press play to watch
From your timeline menu
While watching TV:
  1.
    press the right arrow on your remote to open your timeline menu
  2.
    in your Replay channels, the Replay icon shows if the programme is available to watch
  3.
    use the left arrow to highlight the programme you want to watch and press play
From your channel bar menu
  1.
    press the up or down arrow on your remote to open the channel bar menu
  2.
    find the channel your Replay programme is on, then use the left button to find a programme you want to watch
  3.
    press play to watch
Restart
If you tune in halfway through a Replay programme you can skip back to the beginning. When you see the Restart icon:
  1.
    press OK on your remote to see the Options menu
  2.
    if Restart is available you'll see the Restart icon
  3.
    press the left arrow to highlight Restart and press OK
  4.
    EE TV will take you back to the start of the programme
Or
  1.
    while browsing through your timeline, you'll see the Restart icon
  2.
    press play on your remote to watch the programme from the start
  3.
    you'll also see the icon from your channel bar menu and your TV Guide
Keep Replay
You can also keep programmes in your Replay menu to watch later. Press REC on your remote control, or choose the record icon from programme details.
You can also save any programmes showing the Replay icon in your TV Guide, channel view or timeline menu by pressing REC on your remote.
You'll find your programme in the Recordings menu, even when it disappears from Replay up to 24 hours later.
Can I save Restart content?
If you choose to record a programme showing the Restart icon, it will only part record from the moment you press record.
To record the full programme on one of your Replay channels, wait until the programme has finished. You can then record from your Replay content.
If you do start recording part-way through a programme, then the Record icon on the programme details page will have an exclamation mark in it. The exclamation mark will always display when you record part of a programme.
Turn on Replay and Restart
  1.
  2.
    go to TOOLS & HELP > SETTINGS REPLAY
Turn on Replay settings
If Replay is off:
  1.
    press OK to change settings
  2.
    choose how long you'd like Replay to record programmes for (6 HOURS, 12 HOURS, 18 HOURS or 1 DAY)
  3.
    Press OK to CONFIRM
  4.
    choose which group of channels EE TV will use for Replay, up to six HD (High Definition) or eight SD (Standard Definition) and press OK
  5.
    select your favourite channels and press OK
  6.
    if you see a message saying you don't have enough storage, you may need to delete some of your recordings
  7.
    select which categories you'd like to filter and press CONFIRM
  8.
    you can always change your Replay channels later
Check your Replay group and Replay channels
The Replay group and Replay channels you've chosen are displayed in the Replay settings menu.
Changing your Replay group
Replay group lets you change your Replay channels, for example from SD channels (Standard Definition) to HD Channels (High Definition).
Note: It's not possible to play HD content on all tablets or phones.
If you select this option, you may see a message saying HD channels aren't available for Replay.
Changing your Replay channels
  1.
    press the down arrow to highlight Replay channels and press OK
  2.
    remove any unwanted Replay channels to make space for your new channels
  3.
    choose the channel and press OK to remove the tick
  4.
    select the new channels for Replay
  5.
    when you've chosen your eight standard definition (SD) channels or six HD channels, press OK
  6.
  7.
    your EE TV will start recording programmes, so they're available for Replay
Give us a call
Give us a call
Call now
150
Free to pay monthly
25p per call on pay as you go
Open
Closed
Mon to Fri
Sat to Sun
Ask the Community
Ask the Community
Ask questions and share tips with other people 24 hours a day
Find a store
Find a store
Something went wrong. Please try again later We cannot identify your location. Please enter your postcode below
Finding you
Open Mon to Sat
Open Sun
Need more help
Last updated: 21/12/2018
Sharelle posted this article. Got a comment? Good or bad, we'd be pleased to hear from you.
Was this article helpful?
  • Select a reason
  • The article is too long
  • The article doesn't make any sense
  • Please let us know how we can make it better
0/600
Thank you.
Glad to hear it.
Thank you.
Glad to hear it.
How can I set up programme reminders with EE TV?
How do I use Search with EE TV?
