How can I fix problems with my EE TV aerial?
In this article
Having problems picking up all the channels available in your area or with the quality of your digital TV service? You’ve come to the right place.
Check your set-up
Check your set-up
Sounds simple, but check you've connected an aerial cable between your aerial and the IN socket on your EE TV.
Cable connection between aerial and EE TV socket
If you're using a wall socket, please use the aerial cable and aerial adaptor (if needed) to connect to the IN socket.
Aerial adaptor
If EE TV has worked before, make sure the cable hasn't become loose and that it's still in good condition.
Check your TV aerial
We recommend a rooftop aerial, as the signal may be too weak from an indoor or mobile aerial for you to get a good quality picture or the full range of channels. They can also be affected by other electrical devices in your home. If this is your only option, try moving the aerial as high as possible and as close to a window as you can.
Old or faulty aerials or aerial cable are also common causes of digital TV problems. If you need expert help, we recommend you use an installer registered with either:
Boosters, attenuators and splitters
If you've got a booster, attenuator or splitter connected to your aerial, try removing it as a test (if it's not installed on your roof). If this isn't possible, try turning down the gain and see if this helps. A booster may be causing some disturbance to the signal in strong signal areas. The effect can be the same with a splitter in weak signal areas.
Connector, cable, and STB port condition (physical damage, rust, water damage)
If there’s damage to any of the connectors, cables or ports you may need to get them replaced.
Is the aerial pointing in the right direction?
Is your aerial pointing in the same way (horizontal or vertical) as your neighbours’ aerials? If not, this might be the issue.
Is it a wall socket or direct cable connection
If you're connecting to a cable coming out of the wall, check if the aerial connector on the end of the cable is loose. Use the cable supplied, if possible.
Signal levels
Signal levels are important (Strength & Quality). You can check this from your EE TV box:
  • press MENU on your remote.
  • use the arrows to go to TOOLS & HELP > SETTINGS > TV SIGNAL & QUALITY
  • go to RECEPTION INFO and press OK
  • both Strength and Quality should be at least 60%
EE TV reception info for strength and quality
BER (Bit Error ratio) should be at zero, if it’s more there may be a problem between your EE TV box and the aerial on your roof – check all connections and wiring that you can
EE TV reception info for Bit Error Ratio
Re-scan your EE TV channels
If you've just fixed a problem with your aerial cable set up or you've bought a new aerial, you may need to re-scan your EE TV channels.
Still having problems?
It may be an issue with your digital TV coverage, a temporary outage, the weather or other issues in your area. Find more help.
Thanks for your feedback
Give us a call
Give us a call
Call now
150
Free to pay monthly
25p per call on pay as you go
Open
Closed
Bank Holiday Monday opening times: 08:00-20:00
Mon to Fri
Sat
Sun
Ask the Community
Ask the Community
Ask questions and share tips with other people 24 hours a day
Book an appointment
Book an appointment
You can book a phone appointment with one of our local experts.
Something went wrong. Please try again later We cannot identify your location. Please enter your postcode below
Finding you
Open Mon to Sat
Open Sun
Need more help
