Watch TNT Sports on multiple devices with EE TV
You can watch TNT Sports through HBO Max on different devices, including your TV, mobile and tablet. This guide explains how it works and what to do if you hit a streaming limit.
Watch on multiple devices
You can sign in on as many supported devices as you like. But you can only watch on 2 devices at the same time.
This limit applies to your account, not your broadband connection. This means that, if you have 2 EE TV boxes that are both streaming TNT Sports, no other devices can stream it.
Need to know
If you're using TNT Sports on a mobile device, it will only work on WiFi or the EE network.
Watch on a big screen
You can download the HBO Max app on:
  • Apple TV 4K
  • Samsung Smart TVs from 2015 onwards
  • Xbox One, Xbox One X and Xbox One S
  • PlayStation 4
  • NOW TV devices, including 4K Box and Smart Box
  • Amazon Fire TV devices
  • Android TV devices
  • Roku players
  • Chromecast with Google TV
Or you can:
Streaming limit message
If you see a message saying you’ve reached your limit, it usually means 2 streams are already active on your account.
Sometimes, a device you used earlier may still count as active, even if you’re no longer watching anything.
This can happen when:
  • you switch between devices, like from a TV box to a phone or another TV
  • the app wasn’t fully closed before moving to another device
  • a TV box is in standby but the app is still running in the background
  • you’ve recently updated the app or switched from discovery+ to HBO Max
It can take a few minutes for a stream to stop counting after you leave. During this time, it may still use one of your available slots.
Fix a streaming limit issue
This is the most effective way to reset your active sessions.
  1. Log in to HBO Max on a phone or browser
  2. Go to Profile.
  3. Select Account.
  4. Select Devices.
  5. Select Sign out of all devices.
  6. Wait 5 to 10 minutes before signing in on a device.
This clears any inactive or stuck sessions on your account.
You can also clear a stream on an EE TV box by turning the box off for 60 seconds and turning it back on again.
Was this article helpful?
Thank you for your feedback!
Sorry about that! Why didn’t this article help you?
