When setting up a new iPhone, you can enable iPhone Handoff as part of the process. Your new iPhone will become the main iPhone, and your existing iPhone will be the secondary iPhone.
Before you start, place both iPhones next to each other.
- Start setting up your new iPhone and follow the on-screen instructions.
- On the Set Up Mobile Service screen, select Use Number on This iPhone and Another, then select Continue.
- Review the information from Apple, select Continue, then follow the prompts on both iPhones.
- If prompted about Apple Watch, choose whether to move your watch to your new iPhone or keep it with your existing iPhone.
- Follow the authentication prompt on your primary iPhone to continue to the EE sign-up journey.
- Sign in with your EE ID. If you don't have one, you'll need to create one.
- Review and accept the £5 monthly charge.
- Follow the on-screen instructions to complete setup, keeping both iPhones close together.
- Wait for your secondary eSIM to activate. This normally takes 2–5 minutes, but can take up to 30 minutes.
- To check iPhone Handoff is set up, go to Settings > Mobile Service > iPhone Handoff. You'll see your primary and secondary iPhones here.
