Fix problems with Apple TV 4K
This article provides quick fixes for common Apple TV 4K issues with EE TV, ensuring smooth streaming and an uninterrupted viewing experience.
Update or reset Apple TV
Set your Apple TV 4K to update automatically or follow the steps to update manually.
Apple has a guide on how to reset or restore your Apple TV 4K box.
Common problems
Connection issues
Read Apple’s support if you have connection issues with your Apple TV 4K.
Check Apple’s system status page for service interruptions or find out how to contact a tvOS app developer if a TV app is not working.
No power or picture
If your Apple TV 4K box doesn't turn on or shows a black screen, follow these steps from Apple.
Going to sleep while listening to radio
Your Apple TV box is set to go into sleep mode when inactive. To stop this from happening when listening to radio channels:
  • from the Apple TV home screen, go to Settings
  • then General
  • then Screen Saver
  • select No for 'Show during music and podcasts'
Problems with sound
If you’re having sound problems, check the sound settings on your Apple TV box.
Apple TV 4K warning symbols
Find out what to do if your Apple TV 4K won't start up after a software update or you can see a warning symbol.
Was this article helpful?
Thank you for your feedback!
Sorry about that! Why didn’t this article help you?
