Smart 5G Hub 7 Pro
This article covers the EE Smart 5G Hub 7 Pro, with a downloadable user guide, technical specifications and product support details.
About the Smart 5G Hub 7 Pro
Smart 5G Hub - Image of front of the Hub
Smart 5G Hub
What's in the box
image of Smart 5G HubYour EE Smart 5G Hub 7 Pro
Power supply. Small box with 3-PIN UK plug and cable attachedPower supply
ethernet cableEthernet cable
Image of Keep me cardKeep Me Card
Image of Product safety information leafletProduct safety information
image of paper user guideUser Guide
If you're replacing your Smart 5G Hub 7 Pro, the box might not include accessories. You can reuse the ones from your old hub. If accessories are provided, please use them to replace your old ones to ensure full compatibility with your new hub.
Physical description of the Smart 5G Hub 7 Pro
Image of back of the hub zoomed-in on the ports/connectors. Description of each port follows listed from top to bottom  when looking at the back of the Hub) Braille is positioned to the right of the sockets, except for the Reset button at the bottom of the panel where Braille is on the right.
Connectors, ports and buttons on the rear of the Smart 5G Hub 7 Pro
Round push buttonWPS button – to initiate pairing with Hub
Small pinhole buttonReset button - to reset to factory default settings
A block of 2 ethernet ports
Ethernet WAN/LAN – to connect to your devices
Round push button
Power button – to turn on/off
A small rectangular shaped horizontal hole. The power supply cable plugs into itUSB Power Connector - the power supply cable plugs into it
Setup instructions
Insert the SIM
Lift the SIM slot cover and insert the Nano SIM into the SIM slot in the correct orientation until it clicks into place. For more help setting up, visit ee.co.uk/simstart
Insert the SIM card smoothly into the slot with your finger. Do not use any tools, as this may damage the SIM.
Position of SIM insertion on bottom of the unit
Powering up the Smart 5G Hub 7 Pro
To power up your Smart 5G Hub 7 Pro, connect it to your power adaptor and plug it into a power outlet. Press the On/Off button to power on.
 When the light on the front of the Smart 5G Hub 7 Pro is solid aqua, the Internet connection is available.
To ensure your Smart 5G Hub 7 Pro works and performs as intended, it is recommended that you use the power adaptor provided with your Smart 5G Hub 7 Pro.
Getting Online
For Ethernet access, connect the supplied Ethernet cable between one of the LAN ports on the Smart 5G Hub 7 Pro and the Ethernet port on your computer.
To connect your devices to the Internet using WiFi, search for the Smart 5G Hub 7 Pro WiFi network name (SSID) and use the WiFi password printed on the bottom of the hub or Keep Me Card.
Alternatively, if your device has a camera, scan the QR code on the Keep Me Card to quickly connect.
If your device supports WPS, press the WPS button on the back of the hub for 1 second and follow your device's instructions to connect.
Forgotten your password?
If you cannot remember your password, you can reset it to factory default by gently pressing the Reset button with a paperclip for more than 5 seconds. The hub light will flash green and restart. Follow the instructions to set it up again.
WiFi Compatibility Mode
Your Smart 5G Hub 7 Pro WiFi is secured using the latest technology (WPA2/WPA3 Transition mode). However, some older devices may have issues connecting to a WiFi network configured with this security type.
If you have problems connecting, you can enable the WiFi compatibility mode on your hub by following the instructions below:
  1. Press and hold the WPS button on the back of the hub for 5 seconds until the hub light flashes blue 4 times.
  2. Search for the Smart 5G Hub 7 Pro WiFi network name (SSID) that ends with "-Comp" (for example "Smart-5G-Hub-7-Pro-XXXX-Comp") and use the WiFi password printed on the bottom of the hub or Keep Me Card.
If you have changed the WiFi password on your main WiFi network, it will match your new password.
It is recommended that new devices should continue to be connected to the main WiFi network name if you have enabled WiFi compatibility mode.
What the lights on the Smart 5G Hub 7 Pro mean
Error states are displayed through the light on the front of the Hub.
Colour on the front of the hubWhat it means
No light
Power is off. Check the power connection and press the ON/OFF button to power on your Smart 5G Hub.
Aqua
Your Smart 5G Hub is connected to the internet. If you can’t get online, the issue may be with your device. Try switching it off and on.
Flashing Aqua
Your Smart 5G Hub is connecting to the internet. Give it at least one minute to connect. The light will turn aqua when your Smart 5G Hub is ready to use.
A solid Red LEDRed
There's a problem somewhere. Using the On/Off button, turn your Smart 5G Hub off, then back on. If the light still doesn't turn aqua, use a paper clip to press your hub's factory reset button for 5 seconds.
A flashing Red LEDFlashing Red
Your Smart 5G Hub is working, but isn't connected to the internet. Check if your SIM is inserted correctly. You may be out of range, so try moving the hub to a different location in your property for a better signal.
A flashing Green LEDFlashing Green
Your Smart 5G Hub is starting up. Wait at least 3 minutes for it to turn aqua. If it stays green, turn your hub off and on again. If the light still doesn't turn aqua, use a paper clip to press your hub's factory reset button for 5 seconds.
A solid Orange LEDOrange
Your Smart 5G Hub is disconnected from EE. Log into your hub web UI (http://192.168.1.1) and press Connect on the Status > Internet page.
A flashing blue LEDFlashing Blue
Your Smart 5G Hub WPS is active. Connect your WiFi device to the hub using WPS within 120 seconds.
Flashing White
You have received a text message. Log in to the web UI (http://192.168.1.1) to read your text messages.
Disposing of your old electrical and electronic equipment
To help protect the environment, the UK Government requires that electrical and electronic equipment is not disposed of with general household waste. Instead, it should be collected separately and handled in an environmentally responsible way.
Image of a dustbin symbolising the ability to recycle
This symbol on a product means you shouldn’t throw it
in your normal rubbish at the end of its working life.
This product may contain substances that could be harmful to people or the environment if it’s not recycled correctly. The equipment provided to you will remain the property of EE at all times (excluding outright sale equipment). You’ll need to return it back to us within 60 days of telling us you want to cancel, or we may need to charge you for it. You can do this by following the steps on this page ee.co.uk/returns
As the environment is important to EE, we can get rid of it in an environmentally friendly way.
If this equipment replaces something similar, then you can also dispose of your old kit by following the instructions above.
Returning and Recycling Your EE Equipment
This product may contain materials that could be harmful to people or the environment if not recycled properly. That’s why it’s important to dispose of it responsibly.
Returning Your Equipment
Unless you bought it outright, the equipment remains the property of EE. If you cancel your service, you’ll need to return the equipment within 60 days to avoid being charged.
You can return it by following the steps at: ee.co.uk/returns
Environmentally Friendly Disposal
EE is committed to protecting the environment. When you return your equipment, we’ll ensure it’s disposed of or recycled in an environmentally friendly way.
Safety notice and care instructions
Important safety and care instructions
Your HH70C from EE is manufactured to comply with European safety standards. Please read the following instructions carefully before installing and using it.
Installation and location
  • do not use the HH70C outdoors. Protect HH70C and accessories against rain and or damp to avoid ¬re or electric shock risks
  • position all parts, including power adapters away from heat and sun (eg away from radiator, window still or other electrical equipment which can get hot)
  • keep device and cables out of young children’s reach
  • only use power adapters provided by EE for this device; contact our helpdesk if you need a replacement
  • electronic devices hate liquids; don’t place devices and power adapters in damp area or near sources of water or splashed
  • this device uses wireless technology; check before using or installing where restrictions may apply such as in hospitals
  • product may causes scratches or marks if placed on fragile surfaces (eg veneered wood or delicate fabrics); place on a mat if needed
  • do not use when you are near gas or flammable liquids, strictly obey all signs and instructions posted in any explosive atmosphere
  • use the HH70C at an ambient temperature of 0°C to 45°C. An extremely high or low ambient temperature may cause device faults
Care and maintenance
  • treat all parts with care; no shock or vibration, and don’t pull or twist any cables
  • dust with a soft dry cloth; don’t use water or solvent
  • regularly check that objects don’t cover any parts or any vents that could cause overheating
  • when not in use, store in a dry place and away from extreme heat or cold
Warnings
  • if any parts of your product, power adapters or any cables appeared damaged, discontinue use immediately. Switch your electrical socket if it is safe to do so and contact our helpdesk. See terms in the Guarantee section of the user guide
  • don’t try to open your device or power adapter. There are no serviceable parts and you risk an electrical shock
  • this device has been evaluated for and shown compliance with European Guidelines when installed and operated with a minimum distance of 20cm between the unit and your body
  • if you’ve got a pacemaker please check with your doctor before installation
Compliance information
Radio Equipment Directive Declaration of Conformity
EU
Hereby, EE declares that the radio equipment type HH70C is in compliance with Directive 2014/53/EU. The full text of the EU declaration of conformity is available at: ee.co.uk/declaration-of-conformity
UK
Hereby, EE declares that the radio equipment type HH70C is in compliance with Radio Equipment Regulations 2017 and The Product Security and Telecommunications Infrastructure (Security Requirements for Relevant Connected products) Regulations 2023.
The full text of the EU declaration of conformity is available at: ee.co.uk/declaration-of-conformity.
Restrictions
Operations in the 5.15-5.35GHz and 5.925 ~ 6.425GHz bands are restricted to indoor usage only.
To find the support period for your device go to:  ee.co.uk/help/termsandconditions/general
Information on how to report security issues of the device can be found at ee.co.uk/help/terms-and-conditions/general/reporting-security-issues
Restrictions
This radio equipment is subject to certain restrictions when it is placed on the market in Belgium (BE), Bulgaria (BG), Czech Republic (CZ), Denmark (DK), Germany (DE), Estonia (EE), Ireland (IE), Greece (EL), Spain (ES), France (FR), Croatia (HR), Italy (IT), Cyprus (CY), Latvia (LV), Lithuania (LT), Luxembourg (LU), Hungary (HU), Malta (MT), Netherlands (NL), Austria (AT), Poland (PL), Portugal (PT), Romania (RO), Slovenia (SI), Slovakia (SK), Finland (FI), Sweden (SE), Northern Ireland (UK(NI)), Norway (NO), Switzerland (CH), Iceland (IS), Turkey (TR), Lichtenstein (LI). Wi-Fi 5 GHz: The frequency band 5150-5350 MHz is limited to indoor use.
This radio equipment is also subject to certain restrictions when it is placed on the market in United Kingdom (UK).
In accordance with the relevant statutory requirements in the UK, the 5150 to 5350 MHz frequency range is restricted to indoor use in the United Kingdom.
WiFi radio transmission information
Frequency range (GHz)Max power in the range (dBm)
2.4 ~ 2.483520 dBm
5.15 ~ 5.2523 dBm
5.25 ~ 5.3523 dBm
5.47 ~ 5.72530 dBm
5.725 ~ 5.83514 dBm
5.925 ~ 6.42523 dBm
BandMax power in the range (dBM)Power class
LTE B1, B3, B7, B20, B3823PC3
5G NR N1, N3, N7, N2823PC3
5G NR N77, N7826PC2 (HPUE)
Power Information
Model NumberNPD65AUK AH227
Input Voltage (V)200V ac to 240V ac
Input AC Frequency (Hz)50/60Hz
Output Voltage (V)20
Output Current (A)3.25
Output Power (W)65
Average active efficiency (%)88
Efficiency at low load (10%)72.58%
No-load Power Consumption (W)0.21
PSTI and software support
To find the support period for your device or to report security issues, go to: ee.co.uk/help/terms-and-conditions/general
Other support information
Technical specifications
WiFi standard
WiFi 7
Wireless capability
Tri-band 4x4x4 MLO
2.4GHz
5GHz
6GHz
Wired connections
1 x 2.5Gbps WAN/LAN​
1 x 1Gbps LAN​
Contactless WiFi pairing
Yes
Sustainability
Plastic-free packaging​
Recycled casing
More accessibility information
EE's Here for You section has further information about Getting the most from your devices.
Was this article helpful?
Thank you for your feedback!
Sorry about that! Why didn’t this article help you?
