My TV screen is blank
If you can see an error message, follow the instructions shown on your screen.
If there's no error message:
- Check your TV is using the correct HDMI input. Press Source, Input, Mode or AV on your TV remote and select the HDMI input your TV box is connected to.
- Check the HDMI cable is securely connected to your TV and TV box. If you have another HDMI port on your TV, try connecting the cable to that instead.
- Restart your TV box. Switch it off, unplug it from the power socket and wait 30 seconds. Plug it back in and switch it on.
Freeview channels are missing or the picture is poor
This can happen if there's a problem with the TV signal reaching your box.
- Check the aerial cable is securely connected to your TV box.
- Check whether the channel is available in your area using the Freeview channel checker.
- Go to Settings > Signal & Connection > TV Signal Quality and check the signal for the affected channel.
- Try another aerial socket if you have one.
- Go to Settings > Signal & Connection > Retune Channels to retune your channels.
Bad weather, building work, electrical equipment or a problem with your aerial can also affect your TV signal.
You can check Digital UK to see if there's any planned works in your area which might affect service in your area.
Need to know
If you're watching in IP mode, some channels may not appear in the TV Guide. You can still watch them through their apps in the Main Menu.
See our EE TV channel guide for more information.
Subscription channels aren't working
Your subscription channels use your broadband connection.
If you see an error message, check what the error code means first.
- Check your broadband is working.
- Check your TV box is connected to your hub.
- Restart your hub and TV box.
- Wait for your broadband connection to return, then try the channel again.
Now and again a channel is removed from a package. Check your package details to see.
Channels can also change number - more likely if you’ve changed your package.
The picture keeps buffering or breaking up
If you're watching through your TV box:
- Check your broadband connection is working.
- If possible, connect your TV box directly to your hub.
If you're watching using the TV app:
- Try moving closer to your WiFi router.
- Try another WiFi connection if one is available.
- Pause large downloads or streaming on other devices.
- Use an Ethernet connection if your device supports one.
Using mobile data?
- Move somewhere with a stronger mobile signal.
- Try WiFi instead if it's available.
- Close other apps that may be using your connection.
Still having problems?
If you've tried the steps above and your TV still isn't working, get in touch for further support.
