EE TV Box has stopped working or keeps freezing
This article will help you fix issues with your EE TV box, including freezing and non-functionality, with straightforward troubleshooting steps to restore smooth and reliable viewing.
Check the status of EE TV
If there aren’t any problems with EE TV, you’ll have the option to test your home broadband connection.
Check EE TV status
EE TV Box Pro or Edge is slow or keeps freezing
Try the following to fix your EE TV box if it’s slow or keeps freezing
  1. restart your TV box.
    switch off at the mains
    and wait 10 seconds before switching back on
  2. make sure the TV box software is up to date. To check:
    1. press the ‘Home’ button, then go to ‘Settings’ and then ‘Information & Reset’
    2. select ‘Software Information’
    3. select ‘Update Software’
  3. check your broadband settings and cables to ensure everything is connected securely
  4. the last thing to try is a full reset of your EE TV box
    Be aware that any recordings on your TV Box Pro will be deleted. Other settings will be deleted on both the Pro and Edge boxes.
Remote control
If your TV box is slow to respond to a button press on your remote, it might be a problem with the remote control.
Fix remote control problems
On Demand and Catch Up TV freezing
  1. check TV error codes if you've got one
  2. check for network problems in your area and test your home connection
  3. ensure your cables are all connected correctly
  4. check for TV box software updates (instructions at the start of this guide)
Was this article helpful?
Thank you for your feedback!
Sorry about that! Why didn’t this article help you?
