Check the status of EE TV
If there aren’t any problems with EE TV, you’ll have the option to test your home broadband connection.
New channels or a change to your package
A newly bought channel can take up to an hour to work. If there's an issue with your order, we'll text asking you to get in touch.
Check that the software is up to date
If you do not get a text and your channels aren't working, check your software is up to date:
- press the Home button on your remote
- go to Settings (the cog icon)
- then Software information
- and finally, Update Software
You've got an error code
If you’ve got an error code, use our error code search to find a fix.
A certain channel does not work, but others do
Now and again a channel is removed from a package. Check your package details to see.
Channels can also change number - more likely if you’ve changed your package.
