Compare our Smart Hubs
Choosing the right Smart Hub helps you get faster, more reliable WiFi throughout your home. This guide explains the differences between the available Smart Hubs and the features that matter most to busy households. Use it to understand what each hub offers and decide which one is the best fit.
Quick comparison
Smart Hub 7 ProSmart Hub 7 PlusSmart Hub 6 PlusSmart Hub
WiFi 7WiFi 7WiFi 6WiFi 5
Full fibreFull fibreFull fibre
Part fibre with select models
Full fibre
Part fibre
Advanced Parental Controls and SecurityAdvanced Parental Controls and SecurityAdvanced Parental Controls and SecurityBasic Parental Controls and Security
Detailed comparison
previous
next
FeatureDetails
Model versionSH40J
Processor
Qualcomm Bells IPQ9570
Quad-Core 2.2Ghz
WiFi standardWiFi 7
Number of antennas8
Wireless capabilityTri band
2.4GHz (4x4): 802.11b/g/n/ax/be
5GHz (4x4): 802.11ac/ax/be
6GHz (4x4): 802.11axe/be
Wired connections4 x 2.5GigE LAN
1 x 2.5GigE WAN
1 x FXS (for voice)
1 x USB3 (power only)
Supported broadband technologyFull Fibre only (FTTP)
On/off LED controlsYes
Multiple SSIDsYes
Main/Guest/Compatible WiFi
Contactless WiFi pairingNFC for Guest WiFi
Parental Controls and SecurityAdvanced via the EE app
Cloud backup/Device TransferYes via the EE app
Digital Home Phone supportYes DECT/FXS
WiFi Extender supportYes
Smart WiFi Extender 7 Pro
Connectivity Backup supportYes
Dimensions230 x 110 x 120 (mm)
SustainabilityPlastic free packaging​
Recycled casing
Features explained
Identifies the specific Smart Hub model, indicating its generation and supported features.
Shows the wireless technology used (e.g. Wi-Fi 5, Wi-Fi 6), which affects speed, range, and performance.
Details the number and type of antennas, influencing signal strength and coverage throughout the home.
Explains the Smart Hubs maximum wireless speeds and ability to handle multiple devices simultaneously.
Lists available Ethernet ports and speeds for connecting devices like PCs, consoles, or smart TVs.
Indicates which internet types the Smart Hub works with, such Full Fibre (FTTP).
Allows users to turn Smart Hub lights on or off for convenience or reduced light at night.
Enables separate WiFi networks (e.g. main and guest networks) for improved security and control.
Supports quick and easy device connection using features like WPS, eliminating the need to enter passwords.
Provides tools to manage access, set usage limits, and protect against online threats.
Supports digital voice services, allowing home phone use via your broadband connection instead of a traditional line.
Compatible with WiFi extenders or mesh devices to improve coverage in larger homes.
Was this article helpful?
Thank you for your feedback!
Sorry about that! Why didn’t this article help you?
