Manage 4G WiFi data usage
You can check your 4G WiFi data usage at any time. Connecting through your 4G device:
- In the EE app
- On the EE website
We'll text if you use up your data allowance but it's impossible to go over your limit. If your data runs out, you'll automatically be asked to buy a data or roaming add-on.
How do I buy a data add-on for 4G WiFi?
Whether you’re a pay monthly or pay as you go 4G WiFi customer, you can buy an add-on using the steps below. Make sure you’re connected to EE's 4G network.
- Open your browser and go to add-on.ee.co.uk.
- Go to Purchase and select the add-on you want to buy.
- Activate the data add-on you've bought.
If you pay monthly, the add-on cost will be automatically added to your bill. It'll be on your next pay monthly bill as a one-time charge.
If you're a pay as you go customer, the cost of the add-on will be taken from your top up balance.
Can I use my 4G WiFi device abroad?
Yes, here are a few things to know when using your 4G WiFi device abroad:
- If you’re outside the UK but inside the EU (including Jersey, Guernsey, the Isle of Man and Switzerland) you can use your 4G WiFi device or tablet data allowances to get online with an add-on.
- Make sure data roaming is enabled on your device.
- If you're outside the UK or the EU, the internet won’t work on your 4G WiFi device unless you have an active roaming add-on.
Need to know
You can estimate any roaming costs or roaming add-ons you might need while abroad with our roaming costs calculator tool.
Buying roaming add-ons for 4G WiFi
You can only buy a roaming add-on while you're abroad.
- Select the data add-on you want to buy.
The cost of a pay monthly roaming add-on will be added to your pay monthly bill automatically and will appear on your next pay monthly bill as a one-off charge.
The cost of a pay as you go roaming add-on will be taken from your top up balance.
Using a 4G WiFi device abroad
Need to know
Before you go, make sure that data roaming is enabled.
Make sure you're connected to a 4G network:
- Go to Connection Manager or type 192.168.1.1 into your browser.
- Log in; the default username and password is:
- username: admin
- password: admin. - Go to Settings.
- Select the Data Roaming radio button.
Alternatively, to enable data roaming without your 4G WiFi device, contact us by phone.
You have two options to connect to the internet while roaming:
- manual: your device will only connect when you click Connect.
- automatic: your device connects to the internet automatically when it’s switched on - for ease when roaming abroad select automatic.
How much do add-ons for 4G WiFi cost?
For the latest prices and available add-ons, view the price guide for 4G WiFi.
For more details, view our 4G WiFi Terms and Conditions.
