How do I set up a wireless connection on my Amazon Kindle?
  • Go to section
Getting started
Getting started
To connect using wireless, you'll need your router's wireless network name and wireless password. You'll find these printed on a sticker on the bottom or back of most routers, as seen in the example below.
Router sticker
It can also help to move close to your router while setting up the connection.
How do I connect to my router?
To connect an Amazon Kindle to your router, follow the steps below.
1.    Click the Menu button on your Kindle
Amazon Kindle menu button
2.    Scroll down to Settings and press Select
Settings within Amazon Kindle menu display
3.    The scroll buttons are the up, down, left and right facing buttons. Select is the centre button
Amazon Kindle arrow controls
4.    Select view - you'll find this next to WiFi settings
Amazon Kindle settings menu
5.    You may be asked if you want to Turn Wireless On - if so, select OK
Amazon Kindle wireless message
6.    Locate your router in the list of wireless network connections. In the example below, the router is called EE-1a2b3c
7.    If you can't see any wireless networks, try moving closer to your router and checking it's turned on, then highlight rescan and press select
8.    Press down to highlight your router and select connect
Amazon Kindle list of routers
9.    Enter the wireless password for your router
Amazon Kindle wireless password screen
10.    To enter dashes, press the symbol key
Amazon Kindle symbol key
11.    Press the symbol button again to enter letters
12.    Once you've finished entering your wireless password select submit
13.    The Kindle will connect to your router
14.    You'll return to the Settings page - you've successfully set up a connection to your router
Amazon Kindle wireless connection confirmation screen
Experiencing connection problems?
You may receive the alert Unable to connect to WiFi network, followed by one of the errors below.
  1.
    the password you entered is incorrect or invalid. Select enter password again, making sure you enter the security code correctly
  2.
    internet connection failed. Check your router is definitely connected to the internet. If it is, restart the router and Kindle and try again
  3.
    your Kindle is unable to connect to the WiFi network. You may have moved out of range of your router. Get a bit closer to it and try again
If you're still having problems, try turning your router off then back on again and restarting your Kindle.
Give us a call
Give us a call
Call now
150
Free to pay monthly
25p per call on pay as you go
Open
Closed
Mon to Fri
Sat to Sun
Ask the Community
Ask the Community
Ask questions and share tips with other people 24 hours a day
Find a store
Find a store
Something went wrong. Please try again later We cannot identify your location. Please enter your postcode below
Finding you
Open Mon to Sat
Open Sun
Need more help
Last updated: 4/7/2018
Nikki posted this article. Got a comment? Good or bad, we'd be pleased to hear from you.
Was this article helpful?
  • Select a reason
  • The article is too long
  • The article doesn't make any sense
  • Other
0/600
Thank you.
Glad to hear it.
Thank you.
Glad to hear it.
How do I connect a Smart TV to my wireless router?
How do I connect an Apple Mac to my wireless router?
