Set up Smart Hub (2021) on EE Part Fibre or copper broadband
This page is for
EE Smart Hub (2021)
We'll show you how to set up your EE Smart Hub (2021) with our Part Fibre or copper broadband service.
Follow these steps to set up your hub.
Connect your Smart Hub to your phone line
  1. Plug the broadband cable with the grey ends into the socket marked Broadband on the back of your hub.
  2. Plug the other end into the broadband filter supplied in the box.
  3. Plug the filter into your phone socket.
Tip: Some Openreach sockets come with a built in filter, sometimes called a double master socket. If you have one of these, you don't need to use the filter we sent with your hub.
Power up
  1. Slide the two parts of the power supply together until they click into place.
  2. Plug the power cable into the back of your hub.
  3. Connect your hub to a power socket and switch it on.
  4. Push the hub's Power button.
Check the hub's lights
  1. The light on the front will turn green, to show your hub is switched on.
  2. Wait about 3 minutes for the light to turn solid aqua. Your hub is now ready.
Light not solid aqua? Find out what the lights on your Smart Hub mean.
Connect your devices
To connect your devices to the internet, for example a computer, phone or a tablet, use your hub’s network name and password. You'll find them on the WiFi details card and on the back of your hub.
If your device supports WiFi Protected Setup (WPS), press the WPS button on the side of the hub and follow your device's instructions to connect.
Help connecting devices or tech to your hub
Setting up your other equipment
If you've got other EE equipment to set up, select the options below to take you to the instructions.
WiFi Extenders
Get help with setting up your WiFi Extenders to improve your wireless range.
Set up WiFi Extenders
Connectivity Backup
Get help with setting up your Connectivity Backup. This provides you with 4G signal if your broadband ever goes down.
Set up Connectivity Backup
Digital Home Phone
Get help with setting up your Digital Home Phone service and handsets.
Set up Digital Home Phone
EE TV
Get help with setting up your EE TV box.
Set up EE TV
Was this article helpful?
Thank you for your feedback!
Sorry about that! Why didn’t this article help you?
