What the lights on your EE Smart Hub (2021) mean
This page is for an
EE Smart Hub
This guide will help you understand what the status light on your hub means. It can be used to help understand if your hub is connected to the Internet and what steps to take if your broadband isn't working.
What's the light on your hub doing?
Hub light is aqua
Aqua
Your hub is connected to broadband.
Flashing yellow light
Flashing yellow
Your hub is connecting to broadband.
Flashing aqua
Flashing aqua
Your hub's broadband cable isn't connected.
Yellow light
Yellow
Your hub isn't connected to the internet.
Green light
Green
Your hub is starting up.
No light
No light
Power off or light turned off.
Red light
Red
There’s a problem somewhere.
WPS light
WPS
WiFi Protected Setup (WPS) status.
Aqua light
A solid aqua light shows your hub is connected to broadband.
If you're having problems using the internet, you can check a few things:
Connect device to hub
To connect your device, for example to a computer, phone or a tablet, use your hub’s network name and password. You'll find them on the back of your hub.
If your device supports WiFi Protected Setup (WPS), press the WPS button on the side of the hub and follow your device’s instructions to connect.
Help connecting devices or tech to your hub
Device previously worked
If your device was working before:
  • try moving closer to your hub to check if you're too far away
  • it may be a problem with your device, try switching it off and on again
  • it may be a problem with your hub, try turning it off for two minutes, turn it back on and after five minutes check your lights again
  • check you've not changed the name of your wireless network, select to forget the network and try to connect again
If you're still unable to use the internet, check for any issues with your service.
Check your broadband
A flashing yellow light means your hub is connecting to broadband. Give it at least three minutes to connect. The light will turn aqua when your hub is ready.
If the light keeps flashing yellow or starts flashing aqua, see the steps to fix a flashing aqua light.
Flashing aqua light
A flashing aqua light means your hub  hasn't been able to connect to broadband.
If the light keeps flashing, your broadband cables might not be connected securely.
Hub connected to broadband filter and phone socket
  1. Check one end of the broadband cable is securely connected to the socket marked Broadband on the back of your hub.
  2. Check the other end of the cable is connected to the broadband filter supplied in the box.
  3. Check the broadband filter is connected to your phone socket.
If you have an Openreach socket with a built-in filter (labelled double master socket in the image) do not use the filter provided with your hub.
If you have other phones connected to your telephone line, disconnect these for now, or make sure they're connected to a broadband filter.
Still flashing aqua or flashing yellow?
If checking your cables doesn't help, check the status of your broadband service.
Yellow light
A solid yellow light means your hub isn't connected to the internet.
Connect your hub
If it's the first time you've set up your hub, or you've recently returned your router to factory settings:
  1. Connect a device to your router using an Ethernet cable, or WiFi
  2. Open a new web browser window on the computer or your device
  3. Follow the on-screen help wizard to get connected.
Restart your hub
  1. Turn your hub off using the Power button on the back of the hub.
  2. Wait for two minutes.
  3. Turn it back on.
Check your activation date
If you're new to EE or have recently moved home check your broadband line activation date has passed.
Check for service issues
Check for any issues that might cause problems with your service.
Green light
A green light means your hub is starting up. Wait at least three minutes for it to turn solid aqua.
If it stays green, restart your hub.
  3. Turn it back on.
  4. Wait three minutes for the hub to restart and connect to broadband and then check the lights again
Smart Hub showing On/Off switch and power cable connected to wall socket
If the light is still green after this, reset the hub.
  1. Use a pin, straightened paperclip or similar object to press your hub's Reset button while your hub is switched on.
  2. Hold the Reset button for around 20 seconds until the light turns green again.
  3. Release the Reset button, wait for the hub to start up and then check the lights.
No light
If the hub light isn't on, either the power is off, or you've turned the light off.
Is the hub plugged in and switched on?
  1. Check the power cable is plugged into the socket in the back of your hub.
  2. Check your hub is connected to the power socket and that it's turned on.
  3. Push the hub's Power button to check if the lights now come on.
Has the light been turned off using the hub manager?
It's possible to turn the light off on your hub using the hub manager. To check:
  1. Open your web browser on your device.
  2. Type 192.168.1.254.
  3. Select Hub light control.
Need to know
If you want to make any changes, you'll need your 'Admin' password. You'll find this on the settings card on the back of your hub.
Red light
There's a problem somewhere.
Restart your hub
  1. Turn your hub off using the Power button.
  2. Wait two minutes.
  3. Turn it back on again.
  4. Wait three minutes for the hub to restart and connect to broadband and then check the lights again.
Check the power supply
Check you're using the correct power supply and it's connected securely. If you've recently got a new hub, make sure you use the power supply that we sent with the new hub.
Overheating
 Make sure that that the hub is vertical and the vents aren’t blocked.
Reset the hub
If the light still doesn't turn aqua, reset your hub.
WPS light
When the WPS (WiFi Protected Setup) button on the side of your hub is pressed, the light on your hub will flash.
  • If it's flashing blue, this means it's waiting for you to press or select the WPS option or button on your computer or device.
  • If it’s flashing red, it didn’t connect, give it a couple of minutes and try again.
  • No light means that it’s connected successfully.
Wireless settings and WPS button on hub
Was this article helpful?
Thank you for your feedback!
Sorry about that! Why didn’t this article help you?
