Sometimes device faults occur which stop the device working as it should, even if there has been no physical or water damage. They could be related, but not limited, to a number of different causes such as; a software update which has not installed correctly; out-of-date software; loose parts inside the device; or a malfunctioning battery.
If you think your device is faulty, there are a few things you can do that may fix the problem:
