Enable or disable SSID broadcast
  1. Connect the router to your computer via a USB cable or the WiFi connection
  2. Launch a web browser and in the address bar, enter http://192.168.1.1/, then press Enter
  3. Click LOG IN HERE to access settings
  4. Enter your username and password, then click Log In
  5. Click WLAN
  6. Click WLAN Basic Settings
  7. Click Enable or Disable radio button next to SSID Broadcast
  8. Click Apply
The SSID broadcast has now been enabled or disabled.
