Find out how to enable or disable the firewall on your router.
- Connect the router to your computer via a USB cable or the WiFi connection
- Launch a web browser and in the address bar, enter http://192.168.1.1/, then press Enter
- Click LOG IN HERE to access settings
- Enter your username and password, then click Log In
- Click Security
- Click Firewall Switch
- Tick or untick Enable Firewall tickbox
- Click Apply
The firewall has now been enabled or disabled.
