Get the best WiFi signal at home
Where you position your new Hub is important. Consider these points so the whole family can enjoy a great WiFi signal:
  • put your Hub in the middle of your home (or where you use WiFi the most). If the position of your master socket doesn’t allow for this, then you may need a WiFi booster
  • don’t put your Hub on top of, or close to, large appliances such as TVs, fridges, freezers or microwave ovens. These could block or interfere with your Hub’s WiFi signal
  • keep your Hub off the floor – a shelf or table is fine as long as it’s not metal
Last updated: 20/2/2019
Simon H posted this. Got a comment? Good or bad, we'd be pleased to hear from you.
Was this article helpful?
  • Please select a reason
  • I didn't understand the article
  • I found the information but it didn't resolve my issue
  • Please let us know how we can make it better
0/600
Great!
Thanks for your feedback
We'll use your feedback to keep improving our help articles
